My V-King Pro 3d (with belt driven z)
Hi Bart,
I'm in the middle of a V-King build myself, using a DuetWiFi controller. It would be a big help to me if you could post your config.g and bed.g files for me to look at... Would you mind posting?
Thanks in advance,
Rich.
@richwp Sure I can do that. Although I am not sure you can use it. My build isn't stock:
- 0.9 degree stepper on x and y
- sensorless homing on x and y
- I didn't use the openbuilds cubes on the corners, so my dimensions are different
- I have direct drive now
- I home at xmax and ymax
Other than that, my bed.g is untouched, I have not use it yet.
I am working on the printer now. I'll put my config.g up later.
Thanks - I appreciate it. I have also made a couple of the changes you mentioned as well.
@richwp here you go: 0_1539377068245_config.g
Great - thank you!
