Multi Colour Printing without using wipe or prime towers
Quick update. I've re-written much of the script, fixed the issue(s) and it's working well. I guess it's still pretty ugly as I know next to nothing about writing code but it gets the job done.
As well as the issue with tool changes being close together, I found another couple of problems. The first was that I had made an error when segmenting moves. The E value was apportioned correctly between the two new lines, but the X and Y values were not. The second issue was that under certain circumstances, the tool change position was being inserted after a fast non-print move but before a "G1 F" command which would have resulted in a couple of print moves at 350mm/sec (would have been fun to observe).
All these issues have been fixed. The final test I did was on a file that had 428 tool (colour) changes spread over 154,000plus lines and I ball aching checked every single tool change in the entire file to make sure it was right. More details on my blog if anyone is interested (see signature).
Ian -
Hi Ian…thanks for the hard work and contributions. If I understand the process correctly, you are taking the slicer G-code and inserting your tool change routines at points that correspond to where color changes are expected. Having not yet worked with slicers or G-code I'm unaware of the coding sequences that you describe using Python scripts. Am I missing the entire point of how this works...? Thanks...Terry.
Hi Terry.
You are sort of on the right lines. If you take a gander at my blog, you'll see a post I did on generating gcode files for multicolour objects so I won't go into the details here. The slicer will generate the tool change commands and insert them into the output file. This assumes that the colour change will happen as soon as the machine receives a tool change command. If you have separate hot ends, each loaded with a different filament and each one defined as a separate tool, then this would work fine (apart from the fact that you need to wait while one tool heats up from a lower standby temperature). There are other issues with using separate nozzles but I won't go into those either except to say that you can get unwanted oozing from unused nozzles so it is usually necessary to use some sort of wipe of prime tower.
The advantage of having a single nozzle with multiple inputs, is that you don't have to wait for one tool to cool and another to heat up and you don't have issues with unused nozzles scraping over the print etc. The issue is that if you use a mixing hot end, i.e. a single nozzle but multiple filaments, then when you change tools, there is still some of the old filament left in the mixing chamber so effectively there will be a delay before the new colour comes through. Again the "traditional" approach is to use some sort of wipe or prime tower, but this involves retracting the filament, moving the head to a position away from the print, extruding some filament until the new filament comes through, retracting again, the moving back to the object and resuming printing. This is very difficult, maybe even impossible, to do without leaving a blemish of some sort on the print.
So essentially all I'm doing is taking the gcode file with the tool change gcodes already inserted, but then moving these tool change commands forward in the file. The aim being to change tool at the precise point on the file where the old filament will be purged by the time the new colour is required - not sooner and not later.
This negates the need for any sort of wipe or prime tower. The only thing I can't do is compensate for the fact that there is slight transition where the colour is a mixture of both old and new. However, my work so far has found that this transition is very small (at least it is with the Diamond hot end) so the affect on the quality of the finished print is very slight. In my opinion the print quality is superior to the blobs or blemishes that result in using wipe or prime mechanisms (towers).
Ian -
Thanks Ian…I think I understand the concept. So at the advanced tool change, the current color filament is retracted and the new color filament begins to push to the nozzle end, all the while continuing to eject the old color until it if fully expelled at the desired point in the print. Your calculations of the volumetric characteristics of your hot end of choice determines how far in advance the tool change is positioned in the gcode ahead of the slicer generated position. How are you effecting replacement of the gcode tool changes? Manually or through a programming script of some kind? If code, how do you apply that to the slicer generated file? Thanks...Terry.
Hi Terry,
You are kind of there with your understanding except that there is no retraction of filaments. I've explained the process in great detail in my first blog post which I have made a sticky on my web site. So to save me a lot of typing, you'll find all the answers to your questions here https://somei3deas.wordpress.com/blog/. HTH
I'm a little late to this party but this is a great idea and a clever implementation! Looking forward to giving it a try once I get my swapping working more reliably.
If you are swapping filaments, i.e. retracting one and then feeding in another, you will need purge and/or wipe towers so this technique may not be of much use. You may find that you can reduce the size of the wipe/prime mechanism a bit but that's about the only gain. See the link above to my blog post for a full explanation of how it works.
Oh I know I'll still need a prime tower (or equivalent), but with your technique I would waste a lot less filament.
