Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?
@juice said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
Consider calibrating the printer without using the probe just to get you up and running, It only takes five minutes. It will eliminate any probe inconsistencies and you can always come back to the probe later to tweak that last bit of accuracy.
Agreed! If you set you config.g so that there is NOT a probe configured, when you run the probe command, pop-ups will occur on the web interface that will guide you through "paper probing". This will get you going...
