microprobe biqu toolboard 1lc
Good afternoon, I connected the micro probe, changed the configuration according to the manual, the board sometimes freezes when testing the probe, I saw on the forum that it might be a matter of 5v power, and indeed I supplied 5v power separately from the main board Duet 3 mini 5+ and everything worked, can you tell me how to fix the situation? can I add a 5V capacitor to the 1lc toolboard? Or lay a separate 5v power supply line from the main board?
M558 P9 C"^!121.io0.in" H5 F120:80 T6000 ; BIQU MicroProbe + ToolBoard 1LC Подключение Z probe P - тип зонда, Н - высота погружения F - скорость M950 P0 C"121.io0.out" ; BIQU MicroProbe + ToolBoard 1LC Подключение servo P или S (простой или шим) BIQU = Р, BLTouch = S
