Are Z offsets possible?
After running a bed-leveling macro, is it possible to 'record' multiple values of Z-probing made across the bed surface? Then implement those values to create offsets for Z, that results in a near perfectly flat surface. While my talents lie mostly with electronic design and playing guitar, I'm a fish out of water when it comes to programming.
@Valveman you mean create a mesh? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_mesh_bed
Well....... Duh. Yes Sir, that's what I need! excuse my novice ignorance. I'm guilty of reading thru the tutorials much too fast. I will try my best to comprehend that whole Mesh process. Might need help to fully grasp the challenge. I've never tried to 'edit' the Gcode before, for fear of ruining it. Give me some time to experiment. Should I post my config.g for scrutiny?
@Valveman you can do if you like
