How to calibrate X and Y Axis on duet3 config system
Hi All
I recently had to replaced a damaged belt and I checked my calibration with a test cube and I'm off .020 inches in my "Y" axis. how can adjust it on the system configuration ??
Thanks In advance
@Polo depends on the source of the error. If the error is constant regardless of test print size, it's a different error than an error that would scale with test print size.
How did you measure?
