Duet 3 mini 5+ CAN connection with Bigtree Tech EBB36
Hi! Recently I've got my Duet 3 mini 5+ and want to use it with Bigtree Tech EBB36 tool board through CAN bus - https://github.com/bigtreetech/EBB
The question is - I'm not sure that it's compatible - but why? Maybe someone succeeded with configuration?
Thanks!
@kirill_maker the EBB36 is not compatible with reprapfirmware.
If you want to run those two together you will have to run klipper -
@jay_s_uk That's unfortunate - I've chose Duet because of no need of SBC and fancy interface but with klipper it will be the same like other SBC based MCUs And I can't use roto tool board because I have orbiter extruder and not stealthburner stuff...
I've raised issue on git - maybe one day it will be compatible.. https://github.com/bigtreetech/EBB/issues/129
@kirill_maker you have a choice of the following toolboards that are compatible with RRF
Duet3D 1LC
Duet3D Roto
Mellow Fly-RRF36
Mellow Fly-SHT36 Max V3
Mellow Fly-SB2040 Pro V3
Mellow Fly-SB2040 Max Pro V3 -
@kirill_maker it will never be compatible as it doesn't support CAN-FD and RRF doesn't use support CAN 2.0 for toolboards as its too slow
@jay_s_uk said in Duet 3 mini 5+ CAN connection with Bigtree Tech EBB36:
Duet3D 1LC
Duet3D Roto
Mellow Fly-RRF36
Mellow Fly-SB2040 Max Pro V3Thanks! Will try!
