Why i can't see anymore the preveuve of the sliced files?
I use prusaslicer i think i dont have change anything. -
@Simone we can see in the earlier gcode files that the preview is available. So either something changed in the way prusaslicer encodes the images, or the position of the preview images in the gcode file changed so that RRF cannot find it.
It would help if you shared which RRF version you are using, and maybe the first couple hundred lines of the gcode files that do and do not show the preview image.
@oliof Board: biquskr_rrf_e3_1.1 (stm32f4-wifi)
Firmware: RepRapFirmware for STM32F4 based Boards 3.4.4_103 (2022-11-22)
Duet WiFi Server Version: 1.27-02S-D -
@oliof
this don't show the prewew
; generated by PrusaSlicer 2.7.4+win64 on 2024-04-13 at 18:13:16 UTC;
; external perimeters extrusion width = 0.52mm
; perimeters extrusion width = 0.54mm
; infill extrusion width = 0.54mm
; solid infill extrusion width = 0.54mm
; top infill extrusion width = 0.52mm
; support material extrusion width = 0.46mm
; first layer extrusion width = 0.50mm;TYPE:Custom
G90 ; use absolute coordinates
M83 ; extruder relative mode
M140 S70 ; set final bed temp
M104 S210 ; set final nozzle temp
M190 S70 ; wait for bed temp to stabilize
M109 S210 ; wait for nozzle temp to stabilize
G28 ; home all axis
M572 S0.05
G1 Z10 F240
G1 X2 Y10 F3000
G1 Z0.28 F240
G92 E0
G1 Y140 E10 F1500 ; prime the nozzle
G1 X2.3 F5000
G92 E0
G1 Y10 E10 F1200 ; prime the nozzle
G92 E0G29 S1
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
; Filament gcode
M107
;LAYER_CHANGE
;Z:0.2
;HEIGHT:0.2
G1 X44.36 Y46.972 F12000
G1 Z.2
;TYPE:Skirt/Brim
;WIDTH:0.5
G1 F1800
G1 X45.514 Y46.07 E.05288
G1 X46.814 Y45.352 E.05362
G1 X48.801 Y44.661 E.07596
G1 X50.91 Y44.417 E.07666
G1 X52.564 Y44.527 E.05985
G1 X104.014 Y54.135 E1.88977
G1 X105.73 Y54.662 E.06481
G1 X107.316 Y55.462 E.06414
G1 X108.76 Y56.528 E.0648
G1 X109.809 Y57.602 E.05421
G1 X110.94 Y59.191 E.07042
G1 X178.03 Y168.864 E4.64201
G1 X178.661 Y170.209 E.05364
G1 X179.136 Y171.94 E.06481
G1 X179.296 Y173.728 E.06482
G1 X179.136 Y175.496 E.0641
G1 X178.661 Y177.227 E.06481
G1 X177.883 Y178.845 E.06482
G1 X176.83 Y180.298 E.06479
G1 X175.767 Y181.336 E.05364
G1 X175.266 Y181.735 E.02312
G1 X173.738 Y182.675 E.06477
G1 X172.366 Y183.244 E.05363
G1 X170.616 Y183.642 E.0648
G1 X168.843 Y183.722 E.06408
G1 X167.369 Y183.538 E.05363
G1 X166.745 Y183.395 E.02311
G1 X165.057 Y182.787 E.06478
G1 X163.66 Y182.003 E.05784
G1 X142.429 Y166.935 E.94001
G1 X135.741 Y162.111 E.29774
G1 X130.627 Y158.283 E.23065
G1 X126.711 Y154.952 E.18562
G1 X112.72 Y140.667 E.72195
G1 X78.125 Y103.888 E1.82309
G1 X62.919 Y87.448 E.80856
G1 X49.547 Y71.6 E.74868
G1 X48.714 Y70.303 E.05566
G1 X42.148 Y59.014 E.47153
G1 X41.389 Y57.096 E.07448
G1 X41.051 Y54.999 E.07669
G1 X41.065 Y53.534 E.0529
G1 X41.314 Y52.07 E.05362
G1 X42.012 Y50.086 E.07594
G1 X42.944 Y48.527 E.06558
G1 X44.319 Y47.017 E.07374
G1 X44.319 Y47.017 F12000
G1 X115.874 Y110.153
G1 F1800
G1 X116.609 Y109.768 E.02996
G1 X117.824 Y109.658 E.04405
G1 X118.327 Y109.789 E.01877
G1 X118.703 Y109.983 E.01528
G1 X119.649 Y110.855 E.04645
G1 X120.073 Y111.65 E.03253 -
@oliof this does ; generated by PrusaSlicer 2.6.0+win64 on 2023-09-09 at 11:07:14 UTC
; thumbnail begin 32x32 1348
; iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AAADuElEQVR4Aa1Xu0okQRStv9gPMN9/2G
; DSzWUjMwNBUYxU1kDB9bXIOr7wLcjAqMOAi6OOiqMjrB112lmHk/Uf1N7TcJvbt6tmWlAo6tpTde6z
; Tt0yRvyNjo5Wtre3fx8eHnY3NzeDy8vLNmaMs7OzjpZvbm7+Ql5eXg4h83rMvIZnfFtYWGhNT09/N/
; qvUql8PTk5+aUVMDgDSlkrksa6ZDjFa0n+OTQ09CVTDq/hgfSKN0uvMLMRLPNvkCcnJ2PeD1kaKHEh
; Qyd0GyzEYGDM2msJyvLs7GykQXk/y1jPv7lwr6+v60aDPj8/N1gZwiaBfKC6FrSscaWBhq2WoFoBb/
; YpGB4eTjhd0tgyuLkIMJAsOAaSsg8UMkB1PfTDNVKBC5RzzaBYd3V1Fd7d3cU8tra24larFciCLYtr
; fGGVucJiKHp7e0vCMLQkW8xy8Ldut5s0Go3ShWxYgT5qkg+azWYklT08PNjb21t7f3+fjna7nX6Ta2
; DI8fGxF5dlI0nCFQ1snpubSy4uLjJwAs5FAQZg1Gq1zBCeETkXa7JzRn/gsMEDACC3xJIJ/6/Djgjo
; 6Dw+Pua+Yb9mzVwEdJhQVFoZGZLOR0dHdnFx0e7u7kbEZlG1Wo03NjZ6tLegmKNF0UukHnlK0mPI55
; wrE95yCJFrDjd5YicmJhIJJIuN9sPTTDn2rq2tIQUF1sxSwOTBqUAFSw8AgjkIgoQ8HshutCZ+enqS
; EYiQRkTVVWOFY4jFOowYtKZXlt1QeEiHPhlMSn2peH9/P5Q5l4VUlt1cBYtIuljTyGtThDLNuwwlRh
; l2e3l56bpOCwyQ1zQXvZH0yUB0TSauNDDL+djt9fU1cu3DWF9fT/QpgOykYhQS8b31gcEQ5BkFhhnp
; 8R1bluv1etd1TRtX74ZF5GnAR0pzvyYf1+AU4ujiGMpaKxCR6tcyS2kOiXBy1Tw+Pm5nZmYsRamgUB
; MQcYYlnFjjylrK9QOunvD8/DwgtkuZDqBkUPqd5p7rgsIYGxuzS0tLyHHHh1sgIh+7sYF7e3vhyspK
; Ziy11z2iYBSXXV1dtVNTU6nHRLsRjY4r5K4rukDFvt5N9oe8eX5+PsagPAdle0LZzOY6IlejOajpZF
; DNbh/uCTksn90TagM/rSf0PUI+2hOmERjUu3HLphVIUM1uZR43jFuqJ9Rp6de+ccTK4O7s7PwzeK0e
; HBzU+oH2e/HKKPhe0hqXGLJJHXaVuOJH7oGqH5QS1KXAx279XtKnp6ed9/f3PyMjI9+g+z/BqtBwHo
; i26QAAAABJRU5ErkJggg==
; thumbnail end
; thumbnail begin 400x400 31256
; iVBORw0KGgoAAAANSUhEUgAAAZAAAAGQCAYAAACAvzbMAABbWElEQVR4Ae19W7NdxXVu/4vzA/ye1/
; PKeaAqVcQXoMpgu8qOISRKBCIOIATeCCQkHGMZCYEQCLRBGAMSthTHlQKLS6w4grh8K9kVJ1EeElUq
; SZ23/Q/W2WOdDLnVu7tnX8ZtrtW7ahgjtub8Zo+vx9djdM8xnVujn5tvvvn3Tp48efQv/uIvrt1000
; 0LsKeffvoK2Be+8IUt/DMNA0zf+c53/s7Hhn9mGZv/Z5r4fBwwXuBTK9j8cUJsljlnfT5Y8GvILxiv
; 06dPn4UY48bPav186lOf+l8PPvjgvhTxtImZm7TwZ9rYUvf3g6E1bDjJtYLhlN+0FweDc/TYwA4dOv
; Tenj17vgIxx42f+f/Eso7UhJcmZo1waQTD0lW8RjAsvadGMCz16+BcfDwsc65kPOD3IOaMbGTmP+BA
; WBG0TDBuYrZkPVKZUst9pMpGPdgkgmFYTiv9O1LYVo1zlrFhNuLGz7x+SrMODWL2BlruVWtvMOMM1L
; 3BjHNx0IuNm3O92CQ41/r3rXMOYtEoac3kp1c8OIlJuZqjDoaU2DiCIVV2wxEMKX0xOKd/LZ8nVJyD
; bGSUtAz/gMJTCQcHMXtXWZwk5yhTUJWNuEooFGUjTmxUnKPGRrU44OacNWx43bHBbvCHMuugJqZEDb
; k1UEvsW/Q8P/feQE8w5PbrKnOOG1tPpsSx0Auff2ywG/q55ZZbfn/37t2fcDm8h5gSE7l1YkpjqwmG
; ktjAaoKh1GGBcCxqOCd1cqrWTxqcs4ptHPdV/uHOOnqIqXWOvrRsxL3KmrrvFDaNsSu5rxa2Ej5pYi
; tZHHCU00r9aplzIxtR+IEB379//6bkGfBSYmqRsQSDBWypYCi9sk9hSwVDyZV9ylKLA0ucs4gtxzkL
; 2MZxX6EfrayjlJjaATDE5gdDCxPZNz8YWsPmB0Or2OCfFkTXtxCPBdENsVnm3ChpMf6AeJw/f/64FY
; f7xPz+97//AZhGWWjKNjY2rr777rt/YxEb+NLquKFfLQWZEJvVsXv++ed/NjjX5leIcaOkRfgDigzK
; jDVUKysan5C4srEWbPxVllVsIHDU72X0mr+S5nxJrWfsfM5ZwzY4V29+NWNssBP9xEpWFuqW4UTxsV
; khZqy0Ya0LrI8jVUO34FcrwTDHOW1sMRxU7wJRjV2Iw8qCNMW5scHe8YN9rFLdQjWJORVQNIlZgk0r
; GE6Jv3YwzJ1OG5ybJ+em7q29IM3xfWywN/zUbJRLE7MmwGkQszSIjC6w7dikM6XBORm/Wufc6KdV8N
; NyykqKmK1iJUHMVmxSwbAlq5BaHLSMgVSm1DIGUplSD+e4sbX6R5JztWMw+mllfqY++MTlFKlrcxKz
; 99qcwZAKG4dfKXwiwTnN5+P0q/X5wLEgpfAJ4Bob7N4P5bsd1MSknITUxKQO/NSBmjK4UmdK1H4dnB
; uck/Tr2GD/nx+uPlYUxORawVEQkxtb76qcAxtV8OLKtig5x5VtDc7Jc44rw1/rfloSb5S3kkqivt1z
; D+4ack/ZSKKG3Pr8Uth69qK4OdfTeVhiPrRkShJjZ30+rNUGO4qHxGmHWmJKOLyVmNLYalatUpvK/v
; 1qu8BKnbAZnGs3y5yrHQtpzkE2smvXrpvdqv5o9rEqISb3KquHmNIT2Sfm1CTVwgY2FQw1sZVwTjIA
; 1o5LTTCnNMucK8nOtTm3kiUtC00QU8TUdPgUMaVXWTlixiaN5Corh21unYetcc4aNrBUoNZa6MXGKI
; bNgl9XaoMd+1hpDWiOmFqrrBJiWpnIPjERj0Vsvl8tiK5vIee0Rdc3y5zz8QzO1dnsN9gx62jZGOM2
; 6BZ66dKlCxaxARmxC6w1bGCjC+zqYUPOWZ8PlgK071fL8+Gdd945OLtsxP/gkzVlxpWM35HT2moQV1
; yWsFnOQHDscLwsd0VuPW0kic3qfLBULUB8YNY5N5t+Wqm9DgvEnNoD0SZmDIcVYsYEg/olNUpsYINz
; ZWMX23cbnKvHBmaFc6l9t2PHju01W9Ka2ijXJObUilmTmCWreU1iTm1aagbDqbHTzJRKOWd9Pmj4te
; QUluZ8yPHdOudOnz591lRJq6aPlQYxa8gmTcwaskkTs+Z+0ouDmvtpLA6QRyW/qzEfBuf4sWlwrnQs
; zGywtx7PlVi1tpJfgpitq08pYrYKqUQwbPXr4NzgnLRfLXMOfl/1uC/0sQIla31wTmJSrJy4iEmBjY
; uYlNg4gmHNKitmnGWj3ufmzM6p/Gp9PlD7laoXFud86IkDfj8tJ/VD/VIgJTGpAwQ1MamfdV26wA4/
; 9D8rxbUG59qNcnHAwRGRflpcb5RTEJN7FdJDTM5VeS8xJVblPZOGa+U7ODc4l7vGOmZbbB+sAmWSaE
; XSSkzKVRY1MTkncu89JLC1BgtJbK2c454PrYFscK5tcWCZc5yiG44B6Qa7dB+rGidKOLyVmFIOjxGz
; dJwtn4azesLGOueksbVwTgIbWE2g1uKcRWxk/bRAiTg++FTyAFPEbM0IKGyKmNIOrxkXTWxTAU5adG
; P3nuKcpOj6NjjXh80y53L31uKcv8FenY1Y6J7rO38ub8r6DtfENvUGtObYpVJ4C9h8/1nFluKcNrbB
; uT6/WsZWlY34faw0gfvOt9qDySemNWzofMSmtcrKYRt9v9qwWeac9fmAC1ILC73Qr5Y5N3ncF7MO6C
; xpAXRo0MlUq2Q1ZdiR09JkQYNJYrULLGIDv1rDBjwbnGvHZp1zFrGBL61zbnNz8/EdJS2/ZKW5t5Aa
; VMvKjHg0a6m5scOVPeU5dA6/WsZmiXM+HoucQzyWOednIINzddh2bLDH+lhZIWbMyVaIObUHYhWblX
; p0jHNW69HUL6lR+9X6fNBekKa4ZY1zITbLnLte0soNnhYxSwKdJjGnxFWTmFPjoknMEr8OzqV9VoJN
; i3M5n2kuSKfGRXNBugqccxQPKT2oNQ+pjU2KmLV+kiZmzUmhwbnV5ZxkoK7xkxbnSsZCekFaMxau5I
; ISxOyZmBLEbL2HBDFb7yFBzB5s3JlSD+ckAnUv57ixDc61ca71+SU5V/r7rsUxFnvEcBGTChsXMSlW
; w1zEpOCLZc5xLQ4oOUeNjeq6nJzrve7gXPnfc7U3oiZmreKVYKMiJrWzKInJhY3ietTYODhHjc0y56
; zPB6uco7weJX+pF6Q9ccn13LSHmJylnd5rc9a5KYhJGRRiz91DTE6/9gZqCc61YhucG5xrvbYmNtfz
; AK3E5BxUH1sLMSWwgbUQUwpbKzElNpdbx6B3spXY4Fy/X2uwSR1o6OEc955F6xhQ+dVRPEQpMTWOt9
; YQk7KcRu1EqYns+6qUmFrYSjgnjc3nUSnnNOaDVb9anw8l8UGDczWLA0rRdVQPMDVoGoPqO98ythwx
; pVZZKZsipsQqK2VTi4PBuXbOaWEDG5xr96s05xz1A8SIKb3KSlmMmJoOjznXIrYYMS1hi3FOU3RDHC
; nOaQRA3yxzLobDGud8HNoLvRBHjHMcous4HgIdvbGxcdWCw2PYYDCtYfNJKF1OK8WG+Cz6FbBZ5hw0
; o7PIOcRkZaHnY7PMOevzQYJzjusBYGChs6SlQQ2xwcBawwbjdenSpQsWVqihAZ7Nzc3L0AXWGjbfr1
; Y5B+NmlXNWu8ACHssdatGv68o5R33BUI17j8Fx4ENsVkoJsbHTrkNPYes9esmFDf7dGuf80oZVzgEe
; ayvpGOeszwcLfg3Hiqt8Bea4BrXkz7UcnhtsLYfnsGkTM1VO4yRmr1+tc876fNBeHKTKaYNz7X7lwO
; YoLlIShDWJWUI6rUBdQjotYpbcVysYDs7JcM4iNk3OlWDT5lzud6g55yhA1zhTkpi12KSJmVplpbBJ
; ErN27CSD4SpxTnJxUJttS2fnNdmFdHbe4lfr84HCr64XeMsgSRCzdZAkiNnjQG5i9oioRDAsWWVRPx
; f380ssDixzrhebhF9brr8OnHOSoGPXoSYmlThxEZPimbmISfHMXMGQyh8ciwNqzlEH6sE5PWxgXJyj
; isE9nHNag0o9EFzYqIjJIUiUxKTOCCmDIfXYUV6Pi3PW50OvXzmqEJQLUurF7apyzkncpPTaPQ7jTL
; N7r82ZZvdemxNb7+KAswRAyTlqbP61B+dkOcONrXdB2lpOK7GW+eC0B7X3PlLYWogptQnZSkxO0fWt
; hZjSnLOIbXBucE4LW+l9XMkFuUH7VkNMqUH1rZSYGthKiamJreSeEgHQt5qg2zL5KbBZ5pz1+TB1Ty
; nRbb2nlOiG2Eru6VK/pOHw0kHTcHjN2Eg7vGZsNP06RUzrnNPGVsI5DWxTY2OFc9awgVmfD7nFEuB2
; MZDSq6yc81PYtAbVxxYS0wo2dK5PTG3R9S3GL03RDf06ODc4p4HNMudS2Jz/Sxa7hYIhMTVXWSXOtz
; Z2iMlqF1irnPMDtZUAGPOrlYVeDNvgXDs2q5zzYzByzvm/gJ0bLRESsWFHTmsDC2MFTgezhg0MnA1+
; tbDSivl1cK593Kx3gbW22Av9aplzVudqyDmHDsc/1K71xoDjgFK+l0GJDceq91goJzZLq9UwLbbIOf
; Tj4Fw7Nsucs1YxiHHOWgyOcc6lBlGbmDkHWyAmYMhh03R+CoMFYubGZ3AubynfWeJcOD6WOVdz2kga
; G/43TWw53yFulwOnRcyS+2oRswabtPNLx0SLmCX3tc456/NBOlMq9ZdWoE4t9GLPoIFt7pxzUxeSJm
; atKEgSs5ZoksSsDbySxGzBJsW5loWINOdq7mWZc5KLg8E5Gc65WodwPUAPubiJ2XN9iUypZJWVMm5i
; Uvh1cK7u70pwrvX6Etl5D2+4s/NV45yruQEXMSmcxkVMKqdxEJMSGzUxqTIcrkyJmnPU2Cie2fp8oF
; 4cUGHj5BwFNkuccy03oyImR+CiJCa1WFISk3oCUhKTw6/rwDmOBRo15ygFaXBu/pxzWoPCmY71EpM7
; VewhplQa20pMilUW17NLcM76fLDKuZ5AzVmuo+IcR0msd3FA4VfX+wC1xJSoz/oDVEtM6lUWpfO4J7
; LvI8vYahcHkgcGWgI1co4bW0swG5xr45wUNrBWzlFgcxQPUEpMyUH1nV9yTy1sJcSUFF3fSonJucrq
; vefg3OpyTmKhF/OXRc6V3pMam6N6gCliSq2yUpYjpobDY/e3jC12f21sU0GOapXVg80y56zPB6ucy9
; 1fQ3R9bFMxmHqh56gfIiSmtsNjA4hYtFZZKeeH46SxykphC4lpya9hoLbOOSvYcpyzgG1wrs1CoeDE
; 5jgeAIk5OnLWG2Db3Ny8bBEb4MEmedaw+ZyzILohNuucs4rNMucwMFOd1qI0Kc45LvBWJzM6fnSBbR
; 83i52HfWxWOWcx0PhjZ5lz1ueDhawtNOQbJ+ccx6D6zh7lhDILy2lcLwz1jF2YslsJhoNzbRZisco5
; /HdLApzinEVsnJxz1MBjIC0QMxdUtIlZsmloEZt2MMztYVnhXIpXg3N92CxzTnNxkOJcyysXJeaoQN
; ccIZMkpuUjlb7Dp55Bg5glY8JFTAps/vhaxabFual7Ds61YcPfWxfOOQrgtS8SSk2a2sGSXLW2OFKK
; mC3BQzIYDs7JYAOTCtQ9LxJKBOqShV7v80j5lZJzTgp0aNzE7Fk9cROz5/rcxOzxK3cwtMy53hW7BO
; cstzLp5Zz1+WCVc73YnPSgclyH45ocxKQK/lzErF1lTV2HGtvgnD42Dr9SPO/gXLtfe67jam/GEVSp
; iMlFIipsVknEgY1aLLk4R+EDas5RzgcuzlnERsk5DmzUnKPCBtbKOVcDWiKNtZhi9xKKM8XuJSZ36a
; QnGK4z5yyXdSyUTqawWebcKpUSHfdDtzjf4uZtCzGlsLX4SBpb64EBbmyDc31+XSXOcYpu6FerBwZq
; F6QuB0jS4eF9p4jJvcrqHRMp0Q3HxOrx0VJianGuJFBrc26KS4Nzq8k5rRhcwjmX+iWtQS0ZOAvYUs
; TUxgaWI6ZGAIyNT45zkgGw1HdWOGcRG1iKc1qie1MhrzREt9R3c+CcC3/JgsPDB/AdrO3w2CD62LQn
; cogNsVjCFnKME9sf/dEf3WB/+Zd/GbXvf//7S/v444+3wPDf0S5fvrz8s9TfD+/DNXYh/wfnyjlnfT
; 74C1IrMRixxDgH/+5851vuyGm1wSAMotVmb0hMqw0GEVvr2KEgfPOb37xBBK5cuWLGQiEKxabVr4Nz
; OpzjNMtxDvAA58B8bM7/hY2NjauWwdds7khigzGzOGEQG+DSLA2lrGQyQ5D1BcKSOHCITImwDM61mS
; 9uVuMc+tRqDA4558JUrvcYHLXDQ0dr18nDQfUFzXI5wVJpMobtwoULV86cObO1ykLRIy4oLDBmsflg
; 1a/W54OFBWnMh1ZiMGJJxWCzm+i5+2sTcwqbJjGnhEKbmIDrhRdeuDbEgk5UBuemOZe6v+WDG3OIc6
; 6EGNLEDFdZKdMgZqmwahCzFpsUMbEEBZvTcwrUcxMVEGXI5Abn6u6pkZ2X3lOrIpQTXd9cjSO4H6CF
; ZFLEbFkNSBIzLKeVYuMgJm5uj+xCV1AkToS1zAeJBWlLXJAK1D1xzho2V3ph7nSqZ4C4idkrUpzE7M
; VGRUw8zjqnILuOgrJKnItZb5ySiHOtscBinHO1N6EOhpQZBAcxa1dZOedTE5Nq7FqIObKM+YtJi6BQ
; zTGO7JxjPliNc5TYenzhNAeDo/xERUxObL3O51olTRETRWNOwXLYtJiUZCdcpWKqQE210ON4Zq5YYg
; Gb63mA1nRKYm+gh5jUCp9yWis2zhQ7RswhGusjJrHMRINzluZDT5zj3p+liHM993e9D1AbDLkd3uNA
; aWy1xORYZaXs4sWL10Z5aoiJ1CGQluycqpxWeq8WbFIHaLTinKN4gNKMgntln8M2dV9Jh9eOiRS2sR
; GuZ6+++upic3Nz8dBDDy0efvjhxcbGxuL48eOL5557bvHhhx+qYqPcgC+ZD1Nc15qrpQtSyYWej02j
; 87CjfIhUoNZyeAkGjTPgMefnOnJyi6410YBgumfPnmUwxUD6/PPPLz766CNTOCnsRz/60fJZ77vvvs
; W99957g4Ds379/8fjjjy8OHjy4ePHFF9WxSglJLhhaiCVziHOxrsgc2Bz1A8yp66UlbGA+MbmxWcw2
; zpw5s7j//vuXwdQXEAikTzzxxOLJJ59cqVNfIB5f+9rXigTk8OHDi5dfftkMdgkx8RdPFhZ6IbYwzk
; lXV1ImGYMd1wNA0y1sgMhxj17nW+0WCtg4O3JaPXqLwXRKQOCt9lUREXiWGgGx+OzcQgLz03on7rBD
; rRXzuyJz3cNxXBQVDztyWhpcxGax8zCusgAb9QtD1vc21lFA4HnnLiDcQoIre412HqWxxGLnYakY7D
; iA+4FPsn1B6aD6g2mFmDFsqXpmrc1hYxzKV6UCcv78efPPU2ItAmKpjHWFUUhy80F70Rcrp1kqsYXl
; NI4XI9EcJeicczVrhFPO1SZmbmx6N79gMlsOOGFALRGQv/3bv53NM+UMRbNGQOb07LBwoY4l2gvSqV
; ihuSAticHUmZKjBD4FjOskQM+g+tikiVkjXK3EnFO5B8pY3/jGN7ICsirigQaiUCogcyzd1WQkNat4
; jmBYcs+SOaixIK2NcyaO8bYOlGTXy1pBkCJmy9i1/J05Bp333ntvKSRHjhxZPPvss4u33npr8fbbb8
; /qGWoMRTMnIOfOnZvVM4U2JSQt3JYqG/Vg445zrWNAVRFykoNK+fc5r81JzN5r1xJzvE0+DwPRBAPR
; fOaZZ1ZWOGNC0rLQ820dul1zYKOoCLlWh1EEV46yEaXDVqHzsPVN12HraSAkjz322Bb1fKBa9FEuIr
; k6D1PFpp445zSdFF63ZzC4sfVeF/4+NbYSYkI5ZNX2DYatjrVutOfmQ29g5YwllrG1XNdJPnyJ81sG
; hnvTqoeY3NimfAMCsv3fhogMM2vU75D0LEh7y2klsWSVOg87bdCh1QZqybPXtcTkrH/GnB/zEwoIrP
; S+973vzSqwDFsvAyGhnA81scFynJN+x6QmbjmrHWotd+SccqYWNrCQmL6AwGmfl156aVZBZdj6GXU2
; UtrtWvrdDetxrgSbiwVDC29V5spG3OW0UufPofNwKCBoo6R1o73//vtFNqdnmrNRZyOxOWlhrk51Ht
; bEBjbVediFv2RhUGNALWILiaktuiE2wHPs2LGtmICArWpJ6+LFi0vb9s0NBkdkv/3tby+zstD27du3
; eOSRR6L26KOPJg3e14Ajt2hvvvnm0j744IPrNqexs2aU2ciIc33Y4J9hcuH8X7LaPRe7XloaVN+wI6
; fFsYPgCG87xwQE7NSpU7MKKKFQvP7660sDkQR74IEHFg8++ODyhbyYxcSjV0BS9thjj103+KYJGLzb
; MYSlzihPakH8gO6+VuMcdh7WrK6ksMU6DzscVOxQK/WWeA1wVDwLpavQEJPVzsOQgeQEBL8LYr2kBW
; 1OoHcU9o/afralWMTMooD4Bm+Yo8EXB8FQWCz7QNMoTmrF4pyluYrxw1oMRnxovsC5WLqktamUG1T8
; M4q3JzmxWSEmiu5UBoICAqt3SwEDvkr42muvLf78z//8etda36gEBEpaYPD299GjR5O2LcQ3GJWAxA
; xFZWQqO62nQWMYlC3HOStlrFycW26ipwBa6HqZu/e6db1sxVYjIK+88opaYADBwE/Z+tYiIN/61reW
; +x3+/gfui3Dh9/c8cB8Ey1a1ApISFO1vo89RRKbmqvaCNLdvaqXzcCqOAS5XchHJQF2jvNIqXXM6Ta
; vzcOirGgEBk+ydtbm5uewyC00EQ+GYEhB4Jtz/AOMUBypDgYFyFYpCqYhAU0U0FJN1FpSSklZNfJBe
; kLbEOYvYXMkFpYJhiyBIqXSrWEkQM4etVEDgd1BEOCc+iAYIRmg5AQFsuP8BeyHWglmvlYiKLyBzFR
; OOclxMRFpfQ5BakLYsyqVeragdA1dzca5gSCFQnCo9VU6jdgrlte+5555qAeHMQmLiEQoI4MKSFhcO
; 64EWzBeUlIDExMTSs2BZEvafYM8ISniAk7I9vV/S6p1rnAtSijjAWRFqESinMQhc16POlKixURKzdE
; UyFwFZZ8EoMRAGFJQSMXn++edVxQQyRcge/Y+DoYAAPvg4GGVXBOBw70IvNvctduK2FOdc6wNQBEOu
; Ny2td+SU7jwMIlIjIJzfUEfBgL0PKGdx3WeVDYQBvhMyJSbwFUcQkrNnz4pjBD5NCQjwj3Kxsl3iJK
; +M9JaNuEpPlJ2He67heh6iNRhK1Bpb7yGx39PbebhFuKFWbEFA4KNJnIFr3Qz3P2JiAgLim1RWAtkH
; HHQoERDqk3+ULVDCObdKcY4Km+t9gNqAy1nDi2GryZSkNtFaxoIC22233aYuIMP4LMxMQgEBO3DgwO
; KFF15gFxItAQHjEJHWOEeNw1qcc1QPMZVOSQfn2L1zgVrihEPK+ZIdOUFEYDLnBITzK4YjA5ExEAjI
; OGICAt9YB+MUEjgxVyIgXB0QuETEepzLYeMopznqB7De9dIyttD5nOU0LGkNAVl988XEFxBfSD766C
; Py+8KhiJyAcDfz5BCROcQ5SWyO4wH8YKi1ss853+/IyVlOgyDtWwk2dLIEGSEb2bt37w4B4VoVQm18
; CIiegZCcOHFih4CAHTp0aHHy5ElyIQF/g0E3gO9+97vL912gzCb1zFwiEsY5beEILew8zFVOc1wPsL
; 3i+ZnVrpeA6dKlSxc4sOGR2Ryhc2Lid+TkHgc0EBEUEM52JkNAbBgICWQdoYCgcQiJpnGJCMY5q524
; JWKw47goKp7/T64HaMHG1XkYgnANsUMhCTMQqcMGYHDUlzP7ABub87bMFxJfQNDeeeedWT1PzrhOZ4
; FZzED8WML1YiSY4wId/rlkMIwZ9x5I63l2fIs2NkbSxOTc+wCDTVXNIDIsbiAkkHWEAgLv6sDLfquS
; jVB9VyQVM6gXpK1xLrcHQo3NUV1oKhBrqnQJth6V7n0Z6uOPP97aXgkmx0WCmLXZU61B+WpkILYNhM
; IXEhCQp556ammrko30isjUYlj7FFZJnDN1Cqu2Q61G18uady1qsVEGxRy5OYkpEdjxtJdG0BhWZygk
; voCAQTZi/cNjJdYiIjXzr3dB2mI1wkAZg13PX9Z+C5LjHjWZEkdAzG2ycxCTO/MAwzeTV7GT7iobZB
; 2+gIDB0W/u47cSBryXinNanbg5/l5orgc4RY8Yq10vp1QagjwnwUuykR5iSmYDMFlBQKTuN4zOIBuB
; zMMXELBVyEamjtZb7oV10039e8sUFSHXApqjEySFSlM7K/Ws3OLhWyojaX1W6TISZh8Smc4wPgMh8Q
; UEbe7ZSO3cbzXKspGlGOykbpQzyu+BUCt9LFOS/GofGtwzJiYlmRKIhgZmMPyC4ChfrYZB5hGKiBa3
; KCyW6feu7DljlGScKzGnCTq0VpXuLafVjIGVjWAUFDBoY33x4sVr8E8UCwuTGktXI/tYLYOsI2zIee
; rUqVk9g2/+UXqpTty1cU6qq0eteLrSwCl1LK3mftLYHnvssa05TQxNg2Z6FrMP+HY6GrTXeOONN26w
; Z555ZmlHjx5dHDt2bIe9+eabS8OvBoK9//77Zp5PymD/A7MRPGEHIjLXfRFYfGnEOalO3DVWUxFyuV
; /S7FA7lU5JnHDwTXLfY+7mi4dW9gEC8frrry8N3rB/8MEHlw39QoNvxu/bt2+HQeO/mH3961/fYRsb
; G8smgcePH79u0PMJBUbj+aUMshEUELQ5igi8iyURR1rinNbLiSWdh13sl6QVr0YktLDNuc4rabhpji
; Z1z9dee20ZvOBt9wceeGCHSQhIaPAtczT4RgeKisSYSBrMDV9AYNEwRxGRjCdTImEtBvs4/HKaC39J
; U/Fi5oPVGtTxAlyZ+ZkHZ+kKv58O5RMQjNAsCohv0M4cBAW60mp+t5zSQDB8AQGb26LrD/7gDxaScS
; WMc5KduFtiMMZhH5vDX4L/KN0FtuYBEJu0sI3SVZmF4gH/Tnl9FA34vgTa/fffP1sBCQ0EZRXEBPZB
; UEDmJCKw2NEUEIxz0CVcI86VGHYe9oXNwf+EGYilB/CxafTTGqWraeMSj83NzaXt3r37BuFYRQFZJT
; GBOeOLyBzKWZA5aQpILAZbyUByMdjFNsqtfAgqVk6T7Kc1so+8YYNESvGALANFw7d1EhDf4EuCcxQT
; FJE5LMBwAaQlILHXEDT6aU2Jh//niG3yFJbGfkiJAktkStaJr2mwaY0Bm0I8QDjgTWcQhlA81llA8F
; vmcxSSOWQewGPk7/aCcS3jXMxKqj3XN9F7LyQ9qD42LpUeG+fpCRcG7h7xCPc1hoDEBQQNPkm7Khvv
; Wob7afCtdn8B9MILL1yRjnMlwmA5BruSC0qUjXrKZtQnx0bpaqfBp2hRPMLA3SIeOIFjwjAEJC0gBw
; 4cWH5BEL4kOIQkb1BiBW6CYVcEMORPKCCQgXCXjXr2NyQqQrFyWreAUDw893UpVXpsnP/O/NUaigcG
; bhCUluvBtdAkBWTXrl1L+9KXvrQ4cuTItdOnT1/5kz/5k63PfOYzC998Lnz2s5+N2pe//OWlHT169N
; rhw4e34FkkBQRtCMlOrob7cqGlBAT3QLjKRpZ7YbVe19XeiLpshNkDxbXAelV6ZB//32Aj2w/WoYDU
; igf8vi8cnALyxS9+8bp9+tOfjnKOagLGsnMUma985StLjJwCAvbkk08uXnzxxZX59GwtT8F8Tvmi0C
; Ig6FeqQE19KIm6ItRTwXEaN8W/z1XX67n2Omcf/rHZMGijgLRkHVj64hAQEPw777xzaZY597nPfW5p
; KCrUAgJfDwQDIbHKL0rDvbN77713adQCgtYbqCU4p4nN9TxAq0pLnCxoyZTWLfvw3+iGyZQL2vB7LV
; mHn7VQCMhdd90FJYpr2yWias5x149rOQeCAuOy/TxbVAKCtgpfDYwZ7GsgXyUEpCfQSnKuNQb3Cpuj
; eIhSldZ4EbBGrFYx+8DOs7iZCI0Ft8dkOWHCYB4L2iAcLfcNxaNHQD7/+c8v7rjjjh2TpoRznCvA3D
; 1LAwdOfsxQwuykVUDwq4GWudnCKQj4yCUpAVklzlGX0xzlA+QGTWNQ/UGbwnbhwoUrc5hE0II8PAUE
; rcehBbl/iig8bQQbySAcaDkBOXTo0LKU1TPJcaK3Csgf/uEfLoVjlTmX+u8oJjCGPQKyKp+eBYPFj8
; 8raQEJ/ZbrUDtHzrWao36AWApv4a12xJHqegntnK1PIkjf4TRRKCCPPPLIjmOotQICwQZEA47rtuLz
; xaNVQCDTuOWWW7o4Z6WTQo5zpRlKKCS1ArIKXw3EN8UtCEiKX1Y4l8qUuMppjuMhMChvbGxctdTTxc
; cGjcF8bFdmMJHgLDuVgMC1cA+EApu/QmwREL9E1epXmCBz4lytQVYGga5FQDQ/a9xj/ucBuAWklXOa
; WQc356bMcT0ADGzYudGK+Z2HQZHnsHmOEwkEBL6MVyIgR44cWRqUveDDShDkOVqs40tatQICotErHD
; G/WuUczAeKbte33nrrchFQKyBz/PSs/wIgp4Dcc889XX5ddc6lzFFfMFRjrX5auUFFbIiVYmWGm9Xw
; wSCOF7u42qT3WPjxqBoBoRQOy5wLSxuUJxBRSGoEBOzll1+exb5Iil8cAlLbSHFdOReao7xYKpWzkO
; KlMPR+5xxKQEBgKBFBWwxoawEvi0HzO6oXu7AGrPV52JLJXSoglMIxV85R18tBSGoEZC5fDQzfKOcS
; kJJ3iGJ+DQOydc5xYHMUFymZEBL9tHKDmrpvT/YBBAcSxgQENjthIlNkN0h8ri/8UYjHlIDUTlJqzk
; nybYpzaNTz4e67764SEOsiEgoBtYDAYqYm8ygRCAucy/0ONeccBegaZeNMp1qwtQZ4mHxA1CkB6c0a
; MPuwUrpKiUdKQKiFYxU41/P7UwbZCOyTlQqIpaw25Bm1gMA+xzYHmrLgwbm4uV7gLUorceStZJB6Ns
; 9rBKRnlYfktzKpcyu7UEC4xKOFN1Y4l8NG3VG6VEBeeeUVE/yiFBAUC7DeD0W18kbixelWoaLKlFwP
; 6N6BKUnzW5xW6vCe8hIeW+XMQDBgW8k+/BMxOQHZ/v9b1Ck8Fec4yqhU4kS9ar3tttuWp/GmBAS6E1
; g74lsrINt/tgUtbii/KmiZc5QxuIdzTgs4GqVK12LrnTQlAtK7x2Il+wi/e54SEMw6KIMhdWCl5DDH
; fKCqoXvvY21NCUiriHB2AC4REL9bATXnKIP+HDjXcj1XcxPOdIyi66V040Rs7JYSkHPnznVdu/VjTR
; riARaWrHpX5tQTJYatl3Nc86E3gIVjB3yfEpAWEeEUkNwprNQ+Rm+ckuJc6zU4y7At88FpD2rvfVqx
; Ub48CO0/4B0QeGHvzTffJHkPBCYPTBauyVlqU/seJS9htRBTmnMWsbUEw9zfgZLWlICA1fCDs+uv/7
; 3yMMOdssE5Gc65EuDcoMMHKFXpnkG13tYBJouF77JP7XuUvsFbQ0zuzW4KzkkeRafuArt3796sgNTM
; DRAQzqPAuQyXKj5o9LGquSfHXnHpfJi6p0v9kpTiTTk/ho2inCYVgFsMy1fa731Mla7ghAslMS1wzv
; p8SN2/dqEH5daUgNSICIgH52IMOdi6OT61OND2q/X5kLs/4HaxX5JWvJzzY9h6B9V67yssM2himCpd
; 1YpHjJgS3UKtcI4KWxgMe7ChiMQEpLSUBQICrVE4uXjixInusctxTtqPq8Q55/8Sd+fGVsMHoCqnWR
; cQC9lHrnTVIx4hMS1zDrBJlzZKzJ/AveU0EJGUgJRmFhIvI8KCqnfcLHPOx2aVc4jLX+g5/xewc6P2
; KjAGHrvnUgyshb2FlGH5ShtD755HqV/XhXPU2GDcqLrAQvfmniwEMhCJPUUKERmco+WcCzdzJN6erA
; WOikd1Rt7yBjqcPNEWuFT2QSUe68g5SmwcXWB7shD4HamWKHAvqCC0cM4fN6ucQ2xz4ZxLDSIVMalA
; x/5bKzbLAgLioVm+ymUf3H5dZc71Wu7UDkW9/Pbbb2/OQmAfBAREcl7VZCOp8aF4F4ibc5rYSjjncu
; C0NnJK7ttz9E4yILdMDO37x8SDokVEyaaldc5Znw89q1bIMFuzEChjwe9Kd/edykhK9k398fVfuIRr
; h9aS/awy59zUhSTTqRZRqFXpOZzA0rx/rJNp76Z5rShY55zkqrWW372ZUkpESgI5/J5WY0Y/wIOVcM
; 4Xi48//rjqu0A9+zEtoqDBuZLfdTUX5Uzhe1aeNQ6xLCBQPoI9EM37hwLSu+/R41fLnOPOlHrnQ89J
; ntimekkWUnt6S1JYfKO89rpzzkkSMwe8V11L65mWBQTEQ3P/A9unUJSuqFJvbs5RYKNeGVIFitZ5Fd
; sPKd1Mx98/f/68Go+l50yNP6jmA3V23so5J0lMKtA917R8hFcz+wDz2rF3la44/EoVqDk514uNQyxb
; hTwsZZWesvJFxHq7ICqb2hexzrkebE7rxpzpWE6lh4DEDctXKCCtpSuObIGKM5wlsVXsPNwiIGD+37G1 F2400
G1 X75.711 Y70.841 E.92163 -
@Simone
found the problem! -
@Simone why 2 thumbnails?
@Simone This is how i fixed the probem!
@oliof thx for the help!
@Simone there are two versions of the thumbnail so the PanelDue display can show the 32x32 one. Glad you got this sorted out! Also, for slightly smaller size, you can use QOI format.
