powering duet Vin via relay over USB
Dear Duet,
I would like to power up my duet (the Vin voltage) over USB. So sending a command that switches a relay so that 24v is now supplied to the board.
How would i go about this, should i use the PS-on and correspond ground next to it to go to the relay and than send M80 over USB to power it on?
Kind regards,
@Tricep-terry that's basically the way to do it. Make sure the relay is switchable with 5V. You may need to invert the pson pin depending on wiring and type of relay
