Hiccups and the 1LC tool board
I would like to ask a favour:
If you are running a 6HC main board with a 1LC tool board, I would like to find out what your hiccup count is on your tool board after a print has finished.
M122 Bxx will report the details. xx is the CAN address of the tool board that just did the printing.
Please run M122 Bxx at the beginning of the print to clear the hiccup counter (it resets when the command is run) and then run the same command after your print is finished. The print should probably be more than an hour on the tool board in question - no tool boards that do things like support or separation layer that run only very few movements.Thank you in advance!
Anybody ?
