Check if clicky probe is attached on startup
Original Post:
I would like to include a check at the beginning of some routines to see if the klicky probe is attached to the hot end and if it is ignore any commands to execute a deploy probe that follows. I believe that "if sensors.probes[0].value[0] == 0" is the right command for the test. I am not very knowledgeable on Python so I don't know what commands to add in the lines after that to tell the system not to deploy the probe again and just proceed as it already attached. This is not a situation that would occur very often.Here are my failed attempts to make this work!
homez.g.txt
homeall.g.txt
deployprobe.g.txtI would still appreciate some input on this post if anyone has any? Thanks
This post is deleted! -
@KenW Thanks I will have a look at it tomorrow.
@JADoglio i have a similar probe to the clickeee
echo "Pick up Probe" M564 S0 ; let travel outside print zone if sensors.probes[0].value[0]==0 ; if sensor is value other than 1000 do this, 0 = probe attached echo "Probe already picked up" else G1 X31.25 F12000 ; X position of flint zone G1 Y-34 F12000 ; Y position of flint zone M400 ; wait for moves to finish G1 Y0 F6000 ; slide probe out of dock - slowly M400 ; wait for moves to finish if sensors.probes[0].value[0]=1000 ;throughs a stop because coulnd get hold of sensor G1 X100 Y60 F10000 abort "Probe not picked up!" M564 S1 echo "Pick up Probe fin"
@moth4017 said in Check if clicky probe is attached on startup:
echo "Pick up Probe"M564 S0 ; let travel outside print zoneif sensors.probes[0].value[0]==0 ; if sensor is value other than 1000 do this, 0 = probe attached echo "Probe already picked up"else G1 X31.25 F12000 ; X position of flint zone G1 Y-34 F12000 ; Y position of flint zone M400 ; wait for moves to finish G1 Y0 F6000 ; slide probe out of dock - slowly M400 ; wait for moves to finishif sensors.probes[0].value[0]=1000 ;throughs a stop because coulnd get hold of sensor G1 X100 Y60 F10000 abort "Probe not picked up!"M564 S1echo "Pick up Probe fin"
Moth, thank you this is exactly what I needed. Here is the final version I wound up using, deployprobe.g.txt . Much appreciated.
