Delta Duet 0.85 quality print.
Hello. I have a Delta type printer 280mm x 360mm for Duet 0.85.
it is well built with the use of quality components. I didn't build it. I bought it from the first owner. It is completely metal, carbon arms, e3D hotend, linear guides, bondtech planet gear extruder, nema 0.9step motors, leveling using an optical probe, touch color LCD for reprap. As for the components, they are of good quality for its year of manufacture. Delta now about 7 years old. The construction of the new one cost about €900.
I bought it as my first printer for learning, I liked the build quality. used cost me 200€. I am satisfied, I print at a speed of 100mm/s (edge 50mm/s) in Cura. I can print 3D benches in about 36 minutes. Calibrax cube XY in 11 min. T-rex cup - 6 hoursMy question is - is the print quality sufficient?
I understand that time has moved on, there are new printers, new techniques. but my opinion is that it could print better. I lubricated everything I could, disassembled and cleaned the linear carriages, replaced the nozzle, updated, tightened all the screws, added grease to the extruder gearbox, tightened the belts - basic service.
but it always happens that the Z axis deviates. On one pole I discovered a small ox in a ball. Do you think the print quality is sufficient for my parameters?
sorry, a translator will help me.
This post is deleted!
