[Solved] Sidewinder X1 SKR replacement with Duet 3 mini 5+
Hi all,
After several years using a Duet 3 6HC in my ender 5 Plus, I've replaced the Duet 3 6HC with a duet 3 mini 5+ and I'm saving the Duet 3 6HC for a future project. In the past I posted here my project of replacing an SKR 1.4 turbo with the Duet3 6HC, after long time hesitating and with the duet 3 mini giving great results on the Ender 5+, I decided to pull the gun en replace the SKR with the mini.
That being said, I've starting cabling the new board to the artillery, I believe that I'm mostly done but I'm having some issues identifying some of the cables; I have an adapter on a white cable that you can see at the bottom right of the image.
Can someone please confirm what the white cable is and where should it be plugged in also(I completely forgot to label it
), is any one also using a BL touch or a super pinda with the sidewinder x1 ?
Also I believe I can power up a raspberry pi from one of the 5V connectors if so what would be the best pins to use in this case??
FYI, I have no screen connected.
Thanks in advance for your help.
Anyone using a Duet 3 mini with an Artillery Sidewinder that could point in me in the right direction please?
Thanks
@aldiallo said in Sidewinder X1 SKR replacement with Duet 3 mini 5+:
Isn't the white cable for the TFT screen ?
What is stopping you to follow where the second end goes ?Also I believe I can power up a raspberry pi from one of the 5V connectors if so what would be the best pins to use in this case??
No, it is not advised to power the SBC from the Mini5+
This post is deleted! -
@Falcounet @Herve_Smith
Hi, Thanks for taking the time to reply, actually I ended up answering my question earlier a couple of hours ago and have been finishing the printer configuration. the cable in question if anyone else looks fo the info in the future is the filament sensor.
Concerning the RPI, I'll be running the printer with Klipper not with original firmware hence why the RPI is requiered in my case.
I now got everything working as expected including the filament sensor so all well and good; again appreciate your time replying, especially that it was a dumb prep error on my side when I starting labelling and unpluging the cables from the SKR.
