Adapter for heatsink and surface of contact
I have been using a Smart Effector for years and designed/remixed a few adapters for different hotends - some of them had a wider contact area on the smart effector (the E3D heatsink has a 16mm diameter circle) as well as some arms to use some of the 3 mounting points
A few time, I had the feeling that I've lost some accuracy / inconsistent reading and I have ben suspected the adapter to be the cause.
As I am planning on rebuilding a delta, I was hoping to have some recommendations/guidance regarding the contact area with the Smart Effector and possible (negative?) impact of using some arms.
Thanks
