M300 (beep) not working in SBC mode
Hi all,
running a M300 s666 p666 doesn't produce a sound via the webinterface.
I tested Firefox and Edge.
My mini 5plus in standalone produced a sound on both browsers, the 6HC in SBC mode didn't.M122:
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.01 (SBC mode) Board ID: 08DJM-9P63L-DJ3S0-7J1F8-3S86T-TBJZ8 Used output buffers: 1 of 40 (22 max) === RTOS === Static ram: 154852 Dynamic ram: 90788 of which 1180 recycled Never used RAM 96316, free system stack 199 words Tasks: SBC(2,rWait:,0.9%,354) HEAT(3,nWait,0.0%,323) Move(4,nWait,0.0%,216) CanReceiv(6,nWait,0.1%,794) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,351) TMC(4,nWait,8.2%,59) MAIN(2,running,90.6%,137) IDLE(0,ready,0.2%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:16:25 ago, cause: software Last software reset at 2023-09-29 14:05, reason: User, Expansion spinning, available RAM 96316, slot 2 Software reset code 0x6012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 38.6, current 38.8, max 39.6 Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/1384/1060, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a, mspos 936, reads 30595, writes 14 timeouts 0 Driver 1: standstill, SG min n/a, mspos 456, reads 30595, writes 14 timeouts 0 Driver 2: standstill, SG min n/a, mspos 8, reads 30595, writes 14 timeouts 0 Driver 3: standstill, SG min n/a, mspos 856, reads 30593, writes 16 timeouts 0 Driver 4: standstill, SG min n/a, mspos 8, reads 30598, writes 11 timeouts 0 Driver 5: standstill, SG min n/a, mspos 872, reads 30595, writes 14 timeouts 0 Date/time: 2023-09-29 14:22:18 Slowest loop: 39.17ms; fastest: 0.05ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 54409ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 4, completed 4, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 4 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x10000003 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 8974, received 55168, lost 0, boc 0 Longest wait 56ms for reply type 6041, peak Tx sync delay 271, free buffers 50 (min 49), ts 4930/4929/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 38141/38141 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x25a98 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.0-rc.1 (2023-09-01 07:16:31) Daemon: >> Doing macro daemon.g, started by system Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 38.65, max time between full transfers: 59.2ms, max pin wait times: 61.1ms/11.0ms Codes per second: 6.22 Maximum length of RX/TX data transfers: 5416/1224
