PT100 with 40°C offset
I've install a PT100 sensor form Slice Engineering on a dautherboard (Duet) and the measurments are 40°C up to a measure with an external thermocouple (that gives a true right measure).
What could I do to adjust the measure? -
@Jack What are you measuring with the "external thermocouple"? Please give specifics of the actual temperatures measured. So for instance is it simply room temperature or the temperature of a hotend? If it is a hotend where have you placed the "external thermocouple" a photo showing your test setup would probably help.
