input shaping on a multi tool printer
Is there any way of having different profiles for different heads? Is input shaping even dependent on the mass of the printhead? I am going under the assumption that different tools are within maybe 100 gr of each other and not a situation where one tool is a milling head and the other one is a fly glued to a mounting plate
@jens55 yes. Just put the appropriate input shaper command in each tpre or tpost file
@jay_s_uk .... ohhh, of course .... Thank you !
