help
Hello, can you help me? When I print, my head doesn't reach the centre of the plate.
What settings should I change to bring the head to the centre? -
@labo-dng we would need to know more about your printer before we can answer that. Share your config.g and some pictures of your machine.
@oliof
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue May 16 2023 20:53:37 GMT+0200 (heure d’été d’Europe centrale); General preferences
M550 P"My Printer bad01" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes forwards
M350 X128 Y128 Z128 E16 I0 ; configure microstepping without interpolation
M92 X650.00 Y650.00 Z3200.00 E95.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z1200.00 E3000.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X855 Y855 Z855 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X-20 Y0 Z0 S1 ; set axis minima
M208 X310 Y210 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H15 F120 T9000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X0:300 Y0:200 S20 ; define mesh grid
M557 X0:190 Y0:100 S50:60
M557 R150 S15; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@oliof
flatbed printer 300x200 -
