Connecting Newly Configured Duet MB 6HC
Greetings
I have tested the Duet 3D MainBoard 6HC via YAT Termial for quite a few times. Unknowingly the USB terminal of the Board was damaged and now i cannot connect to the board through USB port.
It is planned to operate as standalone machine without SBC. Is there any options of connecting the DWC with an ethernet cable WITHOUT DIRECTLY CONNECTING THE DUET TO Network or router. Only laptop is connected openwifi
IP Address, Subnetmask and Gateway of the host computer and the Initially configured IP Address, subnetmask, gateway are different. Is there any possibility of connecting these two and use the DWC via ethernet cable?
Ex : Host Computer Details
IP : 10.22.240.14
Subnetmask : 255.255.254.0
Default Gateway : 10.22.240.1Duet3D MB6HC Factory configured Details
M552 P192.168.1.20 S1
M553 P255.255.255.0
M554 P192.168.1.254Apologizes for the basic queries, as i am not sure of the networking & its related concepts
@SANJR yes https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
you can just change the appropriate settings in config.g -
@jay_s_uk Hi
I have read the instructions in the documentation, to confirm my interpretation
I need to change the the IP Adrress, subnetmask and default gateway on the sys folder -> config.g files to match the Host Computer Details,
Duet 3D Before -> After :
M552 P192.168.1.20 S1 -> M552 P10.22.241.14 S1
M553 P255.255.255.0 -> M553 P255.255.254.0
M554 P192.168.1.254 -> M554 P10.22.240.1And Accordingly i have to go to the control panel -> change adapter settings -> Right click on the Ethernetcable ICON -> Properties -> Select Protocol IPV4 -> Select ¨Use the following IP Address¨ -> IP Address : 10.22.241.15 -> Subnetmask : 255.255.254.0 -> Finally click OK
Open Google chrome -> Enter the IP Address : 10.22.241.15 and open the DWC
Is this process correct?
I have no prior knowledge on the network and hence once again apologies on the long request
@SANJR because it's just a 1 on 1 connection between the PC and host, use the IP addresses etc in the example
@jay_s_uk Sorry I am unable to understand.
The IP Address as mentioned in the example to be used as it is?
I tried using the same IP Address as provided in the example but not worked..... -
Connected the Duet to the computer. Thanks for the support provided
