Solved Duet 3 SBC: Stuck on "Setting up reprapfirmware (3.4.5-1) ..."
I'm trying to update a duet 3 6hc with a sbc but apt is stuck on "Setting up reprapfirmware (3.4.5-1) ..."
I've tried to reboot several times but nothing had changed.
The web panel now is always sayng "Starting".
There's a installation log to check or a way to fix this? -
Seems that the firmware files are moved correctly into /op/dsf/sd/firmware, the update process remain stuck on the last line of the .deb postinst:
The duet was working fine on an old 2019 firmware version and the state led is blinking correctly.
I've solved flashing the board using bossa
@morgoth90 if it was really old (something like 3.0 beta) then it had issues with doing an upgrade through the SBC.
