End stop to trigger event or Multiple Filament sensor events
I need an endstop switch to trigger a series of gcodes for an external buffer for the Palette Pro. I'm using a Duet Wifi with a Deux5 running Reprap3.4.5. I have it set up as a filament sensor M591 D0 P1 C"duex.e2stop" S1 which calls the filament-error.g file that has
M220 S5 ; set speed 5%
G4 S5 ;delay 5 seconds
M220 S100 ; set speed 100%This works great but then I cant configure a normal filament runout sensor. Is there a way to have multiple runout sensors with different events or to configure the endstop to trigger an event? Here's the external buffer I'm using. https://www.thingiverse.com/thing:4815921
@chickenwoman could you not just program a trigger using M581?
@jay_s_uk
Thanks! I think I have this right. It seems to be slower executing the M220 S100 in my trigger file. I think I have this set right. There might be a better way but it works!M950 J0 C"duex.e2stop"
M581 T7 P0 S0In my trigger7.g file I have
