Home Assistant Integration
@Lyr3x Yeah that makes sense
Edit 4: With v0.1.1 standalone mode is fully supported and so are multiple tools. I also implemented proper setup to prevent duplicated integrations for the same board, so multiple integrations are support now as well.
Edit 3: We are on v0.0.5 now. Added experimental standalone mode. Canβt test it because I am only using SBC.
Edit 2: Released v0.0.2. All sensors are created properly and getting async status updates every 5 seconds. Ill follow up later to make the interval configurable and I also need to take another look at finishing up the setup when the printer becomes available later
Edit 1: Introduced a bug in the version so that the state is not always updated properly. Working on it
Hey folks!
I refactored quite a lot and we now have a proper integration between the DSF and Home Assistant. When you create the integration via ConfigFlow you have some options you can choose from, including the option to add an LED controller, which is handy if you have LED's connected to your Duet.
The Device itself represents the physical Duet board and shows your correct model as well as the firmware version. All entities now have unique id's and should not conflict anymore. All sensors, binary sensors and the send_gcode service should work properly nowKeep in mind that if you have the integration already installed, you need to remove the integration once more and install it again. That is necessary, because I have rewritten the way of how entities are registered in Home Assistant.
You'll find all infos here in the first release: https://github.com/Lyr3x/hass-Duet3D/releases/tag/v0.0.2
@dc42 it would be nice if we can upload the Duet3D logo here: https://github.com/home-assistant/brands/pulls - we can use the logo then with this integration.I'll look for a better solution for the
Position
sensor soon.
If you find any issues are need additional sensors, please create a GitHub issue from now on:
https://github.com/Lyr3x/hass-Duet3D/issuesI am also more then happy to accept PRs
@Lyr3x Working well so far, many thanks for your efforts!!
Thanks, @T3P3Tony, for the support with the Logos. The integration now appears with a proper icon and the logo!
Unfortunately, I was forced to update the
DOMAIN
object one last time, which results in the situation where everyone needs to re-install the integration completely. Sorry for that! Will try to avoid future breaking changes -
Thanks @Lyr3x for your work.
I have worked on porting the octoprint card to work with you integration.
Anyone interested can check it out here : https://github.com/repier37/ha-duet-card/It has not been tested much besides on my setup, so feel free to report any issues.
btw, @Lyr3x to make your integration work on my setup I had to add authentication. check the pull request if you like to integrate it. -
@Lyr3x Firstly, thanks for your work on this integration which I have now added to my HA instance. I've also just added an ESP32 based "node" to control things like LED lights as well as monitoring humidity and a few other things. I use ESP Home so it's nice that I can have these sensor as well as the sensors from your integration all showing up on the same card.
Some LED strip lights that I have installed will illuminate the lower part of my printer (Z travel is circa 600 mm). So what I'd like to do is set up an automation that will turn these lights on when the Z position is greater than (say) 200mm. What I'm unsure of is how to "extract" the Z position from the sensor.duet3d_position_x_y_z. I note that the state of this entity is in the format [n,n,n]. I can use entity state as a trigger for the automation but how would deal with the fact that it's the third value that I'm interested and the first two values are to be ignored? I've never had an entity with multiple state values so don't know how to deal with it.
@Lyr3x Further to the above, I've found a "hack" that'll do for now but I'm sure there must be a more elegant solution. My hack is to create a template sensor to "extract" the Z position as follows.......
- platform: template sensors: zpos: friendly_name: "Zpos" unit_of_measurement: "mm" value_template: "{{states('sensor.duet3d_position_x_y_z') .split(',')[2].strip(']') |int}}"
It isn't pretty but it works and will do the job for now. I can use this new "zpos" sensor in my automation to turn on certain lights when the bed is at 200mm or more below the nozzle (and turn them off again if it's above).
