My first CoreXY!
Ian, what would be an optimal design? I'm making a similar machine and the z-axis is the same as this one.
Haven't cutted the aluminum parts yet, so there is time for me to change it.Delta guy here… a moving bed is unknown territory
The OP has a great design. I use the same concept with mine, so does Stratasys with the Fortus series. This printer looks well designed and quite tidy.
Fair comment but I've been helping a couple of guys from a company that I met while at the TCT show. They had problems with the Z axis binding because they couldn't get all 4 vertical rods perfectly aligned. So IMO it's not the best design concept.
Sounds like a problem with design rather than concept. If alignment difficulty is the problem I think we could agree getting two actuators parallel should be easier than three.
Hello handicraft friends!
This is a small bridge that prevents the two belts from touching and rubbing against each other. It is a very simple and effective solution. (If you want, I can send you the. stl file.)
http://fs1.directupload.net/images/171116/5htiobas.jpg
http://fs1.directupload.net/images/171116/6pww6zld.jpgNice solution!
