PID auto tune issue E3D Revo
sorry if this turns out to be a double post, but I was editing the original to make it more readable and then it said it was being marked as spam. so not sure if it will be auto removed or not
I switched over to the E3d Revo hot end.
on their support site it indicates the following config changes are needed to use the correct thermistor.M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.060000e-8
my PID auto tunes take over 30 min and always seem to give warnings, is there something else I need to do?
thanks!11/6/2022, 9:37:21 PM Warning: heater behaviour was not consistent during tuning Auto tuning heater 1 completed after 3 idle and 50 tuning cycles in 2030 seconds. This heater needs the following M307 command: M307 H1 R1.456 K0.224:0.291 D2.50 E1.35 S1.00 B0 V24.6 Edit the M307 H1 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN. 11/6/2022, 9:18:28 PM Warning: heater behaviour was not consistent during tuning Auto tune starting phase 4, measuring with fan on 11/6/2022, 9:06:44 PM Auto tune starting phase 3, measuring 11/6/2022, 9:04:59 PM Auto tune starting phase 2, settling 11/6/2022, 9:03:35 PM Auto tune starting phase 1, heating up 11/6/2022, 9:03:30 PM M303 T0 S205
when i try to print i then get this
Heater 1 fault: temperature rising too slowly: expected 0.40°C/sec measured -0.40°C/sec
@ianborg This is indeed a duplicate post and I've replied to your first one.
