2 Part cooling fans controlled by cura (and by one DWC slider)
Hi Community,
I want to controll 2 Part cooling fans (24V) by cura and (by the way) by one DWC slider.
My first thought was to find a solution in Cura. But I couldn`t find a setting for this.My next idea was to change my config from:
60 M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency 61 M950 F1 C"fan2" Q500 ; create fan 1 on pin fan2 and set its frequency
to
60 M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency 61 M950 F0 C"fan2" Q500 ; create fan 0 on pin fan2 and set its frequency
But only one fan is spinning. If I swap both lines each other, the other fan is spinning.
Any idees for my problem?BR
AndreasDuet web control 3.2.0
RRF 3.2
Duet Wifi Server 1.23 -
@sendokhan that won't work like that. Map both fans to the tool in M563 e.g. F0:1
@jay_s_uk
Thank you, problem solved. Have a nice Sunday. -
