Tuning / gcode for expected very slow heating
I am using my Duet 3 and some 3D cartridge heaters to heat up a steel mould.
When I run an M303 command, it fails with the message "Auto tune cancelled because temperature not increasing". What can I do, as a work around to this, so that I can heat the mould up slowly.
@mortarart If the heater is too slow for PID tuning, then the simplest solution would be to use bank-bang control instead. So M307 Hn B1.
@deckingman I'm getting this error with bang bang. I think I am after a way to manually set the expected heater fault time.
@mortarart thats available with M570 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m570-configure-heater-fault-detection
@jay_s_uk thank you! My Google fu failed me this time.
I'm still getting errors that heaters are increasing in heat too slowly. They are increasing, but the mass of steel they're warming is quite large, so there's a lot of lag. This occurs even if the temperature is within the M570 T value, which sets the permissible temperature excursion. For instance, if the heater is at 55c, and I set it to 65c, it faults 30 seconds later.
@mortarart Add or increase the "S" parameter in your M570. Use with caution but if a genuine fault is unlikely to be a fire hazard, then try something like 600 (10 minutes) or even higher
