Input shaping help
@jay_s_uk ok,but with the command M593 I enter the value 41hz which is displayed in my file on the left, right? But where is the center shaper entered?
@jamaicarasta there is a box on the right to set the centre frequency value.
Most of the input shapers are centred around this value (MZV isn't) -
@jay_s_uk ok
I will try M593 P"MZV" F41 and make a test print. -
@jay_s_uk ok i understand, i must activate the hook when i change the center frequency
@jay_s_uk and can i delete the acc file in my system?
@jamaicarasta the file generated by the original accelerometer plugin? yes
@jay_s_uk yes first try without your tips
@jay_s_ukDo I understand that correctly, nothing is required in the system files. The M593 P"zvd" F46 command in the config file is sufficient.
@jamaicarasta correct
@jay_s_uk Thanks for your help man, now the Test print. That was the Print yesterday without shaper. 100mm/s and 7000accel. Not bad with 7000accel. Voron 350 with lgx lite and carbon x axis and 1 mgn12 rail.
