Error: Heater 0 fault: temperature rising too slowly
Whenever I start my bed heater I get Error: Heater 0 fault: temperature rising too slowly: expected 2.30°C/sec measured 0.57°C/sec
How do I change this value? Do I need to change the heater?
This is a 120V bed heater running through a solid-state drive. It is giving 120V to the heater.
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue May 10 2022 16:57:14 GMT-0400 (Eastern Daylight Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"TEVO" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E932.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X360 Y366 Z400 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !zstop ; Z-Probe M558 P9 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:285 Y15:285 S20 ; define mesh grid ; Heaters ;M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp ;M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit ;M140 H0 ; map heated bed to heater 0 ;M143 H0 S120 ; set temperature limit for heater 0 to 120C ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ;M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Heaters V2 ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 S"BiquH2" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings M575 P1 S1 B57600
Perhaps this is a "PID Tune" issue, and if so, how do I do that?
Sry, this was too easy and I gave up before I needed to. I found this code and am running it now...
m303 h0 s100
This post is deleted! -
@the-chairman If this doesn't fix the problem you may have to tune it manually. If so see "Setting the Model Parameters Manually"
@jrcl Thanks... I think I missed a "u" argument which would have used the result, so I might have to rerun it or go your route.
@the-chairman That is for Marlin firmware and you are using reprap. To my knowledge the U argument is not supported by Reprap 3.3. While both based on G-Code they have some subtle differences so try and use this g-code dictionary as much as you can!
There are a few choices when manually tuning but to my understanding using R, C, and D are the easiest as you can calculate them with a stopwatch and Duet Web Control (DWC).
@jrcl Again, thanks. It has finished the auto-tune and gave me this message:
Auto tuning heater 0 completed after 3 idle and 5 tuning cycles in 998 seconds. This heater needs the following M307 command:
M307 H0 R0.532 K0.167:0.000 D13.56 E1.35 S1.00 B0
Edit the M307 H0 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.I didn't see a "V" parameter in that line of code and am not sure what VIN means in this context, in any event. I easily found the line of code in my config.g and have replaced it.
@the-chairman I'm not an expert but this would be used if you used the VIN terminals on the board to power your bed, which you would know. Seeing as you're using a 120V bed with an SSR you probably aren't using those.
@jrcl Does VIN stand for Voltage In, then?
Thanks to everyone here the printer is printing... I am waiting on terminals to finish the CR Touch install and I'm pretty much ready to play with it.
[center]
[/center]
@the-chairman Typically but the scope in which it applies can vary
