Accelerometer - Duet 3 Mini5+ - M955 odd behaviour
I'm hoping to have some help with this one because I cannot figure out what's wrong - The same is happening on both 3.3 and 3.4b7+7
This is on a Delta with a Duet 3 mini 5+ and Smart Effector, I just installed a LIS3DH which is wired properly - I have some samples using the Input shaping plugin on the beta of 3.4.The LIS3DH is connected on both IO2 (+3.3v, ground, in and out) and Temp Daughterboard (MSI, MSO and SCK).
Here what I have to do to get the accelerometer to work:
- M955 P0 C"io2.out+io2.in" => Fail: Error: M955: Accelerometer not found on specified port
- M955 P0 C"io2.in+io2.out" => Fail: Error: M955: Accelerometer not found on specified port (expected as In/out are reversed)
- M955 P0 C"io2.out+io2.in" => Work: Accelerometer 0:0 with orientation 20 samples at 1344Hz with 10-bit resolution
I have not even touched the wires between the commands, I have been able to reproduce it many time so I don't think it's a random issue.
I'm confused, it does not make sense ... maybe I missed a detail it's the first time I setup an accelerometer on a Mini5+
It might worth to mention that the graphs doesn't look good (maybe just some noise??)
config.g
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.5 on Sat Nov 20 2021 16:15:20 GMT-0700 (GMT-07:00) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"SR" ; set printer name M665 R164 L315 B130 H310 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S0 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation ;M92 X80.00 Y80.00 Z80.00 E726 ; Sailfin - set steps per mm M92 X80.00 Y80.00 Z80.00 E562 ; LGX Lite - set steps per mm M566 X1600.00 Y1600.00 Z1200.00 E400.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E3000.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z2000.00 E600.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E500 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io2.in M574 Y2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io3.in M574 Z2 S1 P"io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io4.in ; Z-Probe ;M558 P5 C"!^io6.in" H5 F600 T6000 ; set Z probe type to switch and the dive height + speeds ; xx M558 P8 R0.4 C"io3.in+io3.out" F240 T2400 M558 P8 C"io1.in+io1.out" H5 R0.4 F1200 T12000 A5 S0.04 ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved ;G31 P500 X0 Y0 Z17.862 ; set Z probe trigger value, offset and trigger height G31 P500 X0 Y0 Z0 M557 R120 S30 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S0.90 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S80 ; set temperature limit for heater 0 to 80C M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S240 ; set temperature limit for heater 1 to 240C ; Fans M950 F0 C"out2" Q2500 ; create fan 0 on pin out5 and set its frequency M106 P0 S0 H-1 C"Part Fan" ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out6" Q100 ; create fan 1 on pin out6 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Set Extruder pressure advance M572 D0 S0.10 ; Custom settings are not defined M501
Log in 3.3 with some M122 (log is too long to be paste here)
Mini5-log-v3-3.txt -
undefined Fred-Y marked this topic as a question
