My print is too much tall
Can someone explain me why my cube is not... a cube...
Leadscrew are TR8*8 and this is my parameter in config.g :
M92 X80.00 Y80.00 Z800.00
Is this line false? Is it something else?
@arisoy try Z400
@arisoy To expand on what @jay_s_uk has said.....assuming your stepper is a "normal" 1.8 degree motor, then it has 200 full steps per revolution. A TR8 screw has a lead of 8mm meaning that a nut positioned on the screw will travel 8mm in one revolution - or in your case, the Z axis will travel 8mm for one revolution of the screw. So we have 8mm = 200 full steps therefore 1mm will be 25 full steps. Assuming you use 16x micro-stepping that's 400 (25 x 16) steps per mm.
@deckingman Thanks for your explanation. I did the calculation too but somehow i miss something...
Thanks a lot everything is working fine now
@arisoy Glad you got it sorted. Maybe you did the calculation for 0.9 degree steppers? - They have 400 full steps per revolution which would be 50 full steps per mm, so 800 would be correct for a 0.9 degree motor.
