Toolboard 1lc additional header?
Filling out my wishlist for Santa this year
I'd like to see one of the 3 pin headers on the 1LC have a built-in BAT diode on the input with the ability to change +V pin voltage to 5V or V-IN to simplify wiring. Perhaps a stretch would be to offer all voltages (3.3, 5, 12V, V-IN). The use case would be for NPN inductive probes, or easily changed for other uses (think BL-Touch, endstop switch, etc) but still allow an easy hookup. Perhaps a solder jumper to set-and-forget?
@th0mpy i think the pinout is already 30V tolerant. You could use the Vin from the out pins?
@pcr I think you still should have a diode on the input right?
Looking for a single header that will power the inductive probe and accept the signal generated. As well, it should be flexible to offer a few different voltages. I thought that a diode would be required to fully satisfy all the requirements.
