Question regarding accelerometer
Hi I recently installed my accelerometer but I’m a tiny bit confused as to the orientation code
M955 P0 I60 C”io8.out+io8.in”
Is the code I used my machine is a core xy and I used the lis3dsh mounted on tool head
From THE M955 page:
The I (orientation) parameter tells the firmware which of the 24 possible orientations the accelerometer chip is in relative to the printer axes. It is expressed as a 2-digit number. The first digit specifies which machine direction the Z axis of the accelerometer chip (usually the top face of the chip) faces, as follows: 0 = +X, 1 = +Y, 2 = +Z, 4 = -X, 5 = -Y, 6 = -Z The second digit expresses which direction the X axis of the accelerometer chip faces, using the same code.
The chip looks like this:
So:
- Which axis does the top of the chip face?
- Which axis does the "X" axis face? (Look for the white dot on the package to figure out which way "X" is on the package. I can't tell from your photo.)
@alankilian x is to x, z is to the front of printer so 20?
@bzad said in Question regarding accelerometer:
Is the front of the printer the +Z axis? (This would be unusual.)
Can you show a photo of the whole printer with the head as well as a closeup pf the accelerometer board?
Or a link to the accelerometer board so I can see which way "X" points on the board? -
I'm going to GUESS you took that photo standing in front of your printer, so I think the accelerometer +X axis is pointing in the +X printer axis direction and the accelerometer Z axis is pointing in the -Y printer axis direction.
So
I50
GUESSING.
@alankilian
The board
https://a.aliexpress.com/_mOkoSpqAnd yup standing in front and x is +x and z is pointing to -y is what I meant to say
Thanks
