move.compensation.meshDeviation from heightmap
currently move.compensation.meshDeviation.deviation is only populated after a G32 run, but not after G29 S1 or M375.I would like to use this value (actually the max deviation) to automatically compute the right taper value according to the M376 documentation (i.e., 20x move.compensation.MeshDeviation.deviation); but if this is only possible after a G32 run.
So as a feature request, this should also be populated after loading G29. And since the heightmap plugin also can show me the max deviation, adding that to the model and not just RMS deviation would be great (-:
