Display Heading not showing Under Files Section
I have files in the menu folder and M918 P1 in the config. But. The "display" heading is missing on the menu under files. Any help? Duet 3 Mini 5+
@mdunfee there's no longer a separate "menu" tab.
Navigate to the system tab and at the top left of that window there is a box that'll say system with a drop down arrow. You will find menu has appeared there as an option -
@jay_s_uk what i am missing is display in this area
. If its no longer there, then ok. JUst trying to get the display working with the system.
@mdunfee have a look here
You need to press the little arrow next to the system directory, you can then select menu directory
