Duet 3 "Extruder 0 has no filament sensor" after configuring.
So I am trying to configure a simple switch sensor to a 6HC (that has a expansion board attached)
I have configured my sensor as such
; Filament Sensor
M591 D0 P1 C"io4.in" S1But the console returns this after sending M591 D0
M591 D0
Extruder 0 has no filament sensorNo M591 commands in my overide.g
Attached is my config.g
; Configuration file for Duet3 Mini5+ with Mini2+ expansion (firmware version 3.3 or newer)
; executed by the firmware on start-up; General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M83 ; ...but relative extruder movesM669 K1 ; Select CoreXY mode
M564 S1 H1 ; Forbid axis movements when not homed
M575 P1 S1 B57600;
;M564 H0 S0
M550 P"Ray's Voron" ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP (for DWC)
M586 P1 S1 ; Enable FTP (for remote backups)
M586 P2 S0 ; Disable Telnet; --- Z Drive map ---
; _______
; | 1 | 2 |
; | 0 | 3 |
; front
; (looking at the printer from the top); Drive directions
M569 P2.0 S1 ; physical drive 1.0 goes forwards
M569 P2.1 S0 ; physical drive 1.1 goes forwards
M569 P0.0 S0 ; physical drive 0.0 goes forwards
M569 P0.1 S0 ; physical drive 0.0 goes forwards
M569 P0.2 S0 ; physical drive 0.0 goes forwards
M569 P0.3 S1 ; physical drive 0.0 goes forwards
M569 P2.2 S0 ; physical drive 1.2 goes forwards; Motor mapping and steps per mm
M584 X2.0 Y2.1 Z0.0:0.1:0.2:0.3 E2.2
M350 X16 Y16 I1
M350 Z16 E16 I1 ; Use 1/16 microstepping with interpolation everywhereM92 X80 Y80 Z400 ; Set XYZ steps per mm (1.8deg motors)
;M92 X160 Y160 Z400 ; Set XYZ steps per mm (0.9deg motors)
M92 425.13 ; Set Extruder steps per mm; Drive currents
M906 X1500 Y1500 Z1200 E800 ; XYZ and E current
M906 I30 ; Idle current percentage
M84 S120 ; Idle timeout; Accelerations and speed
M98 P"/macros/print_scripts/setup_printing.g"; Axis travel limits
M208 X350 Y357 Z325 S0 ; Set axis maxima; Endstops
M574 X2 S1 P"^io1.in" ; Xmax endstop on hall effect board
M574 Y2 S1 P"^io2.in" ; Ymax endstop on hall effect board
M574 Z0 S1 P"nil" ; No Z endstop; Filament Sensor
M591 D0 P1 C"io4.in" S1;M955 P0 C"spi.cs3+spi.cs4" I65
; Z probes
M558 K0 P8 C"^io5.in" T18000 F400 H5 A5 S0.01 R0.2
G31 K0 P500 X0 Y25 Z0 ; Don't really care about inductive probe Z offset
M558 K1 P8 C"^io3.in" T18000 F400:60 H2 A10 S0.005 R0.2
G31 K1 P500 X0 Y0 Z-0.21 ; Z switch offset (if positive, greater value = lower nozzle. if negative, more negative = higher nozzle); Bed leveling
M671 X-65:-65:365:365 Y0:395:395:0 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
M557 X25:275 Y25:275 S25 ; Define bed mesh grid (inductive probe, positions include the Y offset!); Heaters
;HE0
M308 S1 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 0
M143 H1 S280 ; set temperature limit for heater 0 to 280C; Bed heater
M308 S2 P"temp2" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0 (heater sensor)
M950 H0 C"out2" T2 Q10 ; create bed heater output on out2 and map it to sensor 2 (mic6 sensor). Set PWM frequency to 10Hz
M140 P0 H0 ; Mark heater H0 as bed heater (for DWC)
M143 H0 S120 ; Set bed heater max temperature to 110°C, use implict monitor 0 which is implicitly configured for heater fault
M307 H0 B0 S0.6 ; disable bang-bang mode and set PWM to 60% to avoid warping
M570 H0 P400 T15;CHAMBER TEMP
M308 S3 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
M950 H2 C"out8" T3 ; create chamber heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
M141 H2 ; map chamber to heater 2
M143 H2 S100 ; set temperature limit for heater 2 to 100C; Fans
;HE FAN
M950 F0 C"out4" Q20 ; Create fan 0 (hotend) on pin out3 and set its frequency
M106 P0 S1 H1 T50 C"Hotend" ; Configure fan 0: Thermostatic control is turned on, based on sensor #1;PART FAN
M950 F1 C"out3" Q20 ; Create fan 1 (cooling) on pin out4 and set its frequency
M106 P1 S0 H-1 C"Cooling" ; Configure fan 1: Thermostatic control is turned off;E BAY FAN
M950 F2 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
M106 P2 C"E Bay" S1 H-1 ; set fan 3 name and value. Thermostatic control is turned off;CHAMBER FAN
M950 F4 C"out5" Q500 ; Create fan 3 (chamber) on pin out6 and set its frequency
M106 P4 S1 H3 T55 C"Chamber" ; (temporary manual setup); LEDs
M950 F5 C"2.out3" ; Create fan 4 (top leds) on pin out2
M106 P5 S255 B0 H-1 C"Top Lights"; Tools
M563 P0 D0 H1 F1 ; Define tool 0 using fan 1 for M106
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Misc
;M572 D0 S0.02 ; PLA PA
;M592 D0 A0.015 B0.0012 L0.2 ; Non-linear extrusion
M376 H3 ; Fade mesh out compensation over 10mm Z
;M912 P0 S-8.5 ; MCU temp calibration; DAA tuning (you will need to change this for your slicer)
;M593 F35. ; Cura 4.5 stock profile @ 40mm/s outer printing speed
;M593 F42.5 ; PrusaSlicer @ 40mm/s outer perimeterM80 ; turn on PSU & mains voltage
; set default LCD color
M150 X2 R100 U80 B255 P250 S3M501 ; load config-override.g
T0 ; select tool 0 -
@dommilan please see here https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations#Section_Permanent_limitations
Filament monitors must be connected to the same board as the corresponding extruder motor. This use so that the firmware can correlate the measured filament movement and the commanded extruder movement in real time.
@dommilan Not sure what happened, bit M591 D0 now returns: Error: M591: Driver 2.2 has no filament monitor
