Duet 3 6HC Ethernet Port
Is there suppose to be any lights lit up on the ethernet port when an ethernet is plugged in? I see two lights near the bottom of the ethernet port on the board (green and yellow it looks like). When I plug in a cable, these do not turn on. Is this normal?
@frank-0, no, the lights show ethernet connectivity and will flicker in normal operation.
@jens55 So something is wrong with my duet?
@frank-0 ... or with your ethernet cable or with whatever is on the other end of the cable or your config file or .....
I had the same issue at one point. Turned out that I didn't have things set up correctly in the config file. Oh, it also takes a few seconds (in my case) for my switch to recognize the new port before things would start flashing.
These are the essentials for MY config file:
; Networking
M550 P"printer name" ; Name used in ui and for mDNS http://Jubilee.local
M552 P0.0.0.0 S1 ; Use Ethernet with a static IP, 0.0.0.0 for dhcp
;M553 P255.255.255.0 ; Netmask
;M554 192.168.1.1 ; GatewayNote that the last two lines are commented out for my application.
@jens55 Is it possible for you to see what is wrong with my config.g file?
; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jul 13 2021 19:22:41 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"Printer" ; set printer name; Network
M551 P"Secret" ; set password
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M584 X0.0 Y0.4 Z0.2 E0.1 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E2800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z1 S3 ; configure sensorless endstop for low end on Z; Z-Probe
M558 P0 H5 F120 T1200 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp2
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Propellant Print Head" D0 H1 F0 ; define tool 0
M575 P1 S1 B57600 ; enable support for PanelDue -
@frank-0 I see the essential M552, I do not know about the password M551 call as I don't use a password to connect to the network.
I am afraid I am the limits of my knowledge here. I would go and see if the 6HC shows up in the router IP listings and go from there. There are really endless possibilities starting with a defective network cable. Have you hooked the cable to another device and checked for traffic?
