thermal fuses any advice ?
Hi , on to phase 2 of my BLV mgn cube build and it's time for safety .
Phase 1 meaning get it working ,
Phase 2 make it neat and think about long term safety like earthing and fusing.
Phase 3 fit extras like leds and side panels .Just earthed the mains heated bed as I may be using a magmatic spring steel top and I don't want to die just yet , looking at thermal fuse all the one I can find are like resistor , are they any which give you insulated wires etc.
I only have 5mm of bed which is not covered by the heater mat. -
@peter247 I use these on my RailCore and Vorons
If you are in the UK, i could send you one.
Regards,
Paul. -
@peter247 I use this style but you may not have room to fit one Thermal Cutter out and back it up with one of the resistor styles at a higher value just in case
@paulhew THANK YOU , Yes I live in the UK , is there anyway I can send you a personal message on this forum ?
@peter247 Sent you a PM
