PanelDue Firmware 3.3.0-rc2 released
Hey @fotomas, can you create a seperate thread for this feature request, please?
@davea ctrl-shift-space will insert a "nonbreaking space" character which will be hard to see and mess with your head. Maybe that happened.
I'm note sure if this is related to this release, or if it's only that I have only just noticed.
It seems that if the PanelDue screensaver activates during a long loop, touching the screen doesn't wake it up afterwards, despite popups like M291 working during the macro loop (whilst the screen saver is active).
@owend I was about to post the same issue. Happened yesterday, after a filament runout pause, the panel due was locked on screen saver. Couldn't wake it.
@OwenD @KipK thanks for reporting the issue. I will try to reproduce it.
So what i understand the process is:
- wait until screen saver is activated
- then trigger a message M291 to display
And you expect that it should wake up in such a case? Did you realize different behavior with previous versions?
BTW i agree it would be definitely handy if the screen gets activated and shows the message to the user.
@mfs12
No, the M291 worked despite the screen saver being active.
The screen saver could not be woken.
I suspect it's more to do with long loops. -
@owend sorry. to ask again. but now i am getting a little confused. could you please try to describe a step by step process to reproduce the issue. It would be very helpful.
@OwenD @KipK the issue displaying M291 message while screen saver is active is tracked now at https://github.com/Duet3D/PanelDueFirmware/issues/147
The M291 screensaver bug got fixed. Will be part of 3.3.0-rc3.
@mloidl the times left issue describes is going to be fixed with https://github.com/Duet3D/PanelDueFirmware/issues/152
