failed to connect to duet 3 (dwc is not started)
I am a newb and have my RPi 4b connected to the D3M5+ via the included RPi to Duet 3 ribbon cable and the Pi updated itself and updated the board as far as I know and now when I try to access the DWC I keep seeing "connecting" onto infinity and in the lower right hand corner I see "failed to connect to duet 3 (dwc is not started)" What is going on how to proceed?
@pickett Do you have an SD card in the Duet?
Can you also connect to the Duet via USB and get the output of M115?
