Toolboard v1.1 Accelerometer Orientation and Setup
@martin7404 i will have a look at the specs. since im using a Lc1 v1.1, i already have 24v,12v and even 5v to choose from, but i wanted to run the probe with 24V so i get a little bit better readings and distance
@frederik it’s not an orbiter. It’s a ground up design I worked on, though it does use a planetary gear as part of the design. Lorinz and I have often talked about design and 3D, and one late night discussion seemingly drove us to explore similar things, but implemented in different ways. Mine is fairly specific to the BLV, though I made a more generic version for coreXY type designs. Mine also uses more generic nema11 motors like those from moons and offsets it so the extruder itself sits much lower and on top of the hotend for minimal filament travel.
@nuramori Thanks for the Info. Looking real nice ! What buildvolumoe do you have ? my vcore Pro is around 430x430x400mm and until now, i managed up to 410mm/s wiht a genuine BMG and a mosuqito magnum with 0.4mm Nozzle at 0.25mm Lh and 0.46mm Lw
