Filament config.g on printer power up
Hi all,
after finishing tuning my printer and done all the profiles i need on my slicer, i'd like to leave the filament managment on the duet board. I've noticed that when i power on the board, the firmware remember the last loaded filament and it's showed in DWC. However it seems that it's not loading config.g of that specific filament till i do a unload/load or switch filament operation. Am i missing something? I think that DWC should not show a filament loaded with this behaviour or, better solution for me, is that also config.g of the loaded filament should be processed on board power on. -
@owend Thank you...i open the gcode dictionary nearly everyday and i'm still missing some However as suggested in the dictionary i've put in tpost0.g (i'm on a single extruder) so i'm sure that it is always called and, if no filament is loaded, i can stop the print with a conditional gcode.
