Help with mini5 M587 wifi.
Feel like a wifi noob...
I have followed the guide but for the life of me I only get a connection to the gateway 255.255.255.255.Getting started+Getting+Connected+to+your+Duet/7)
Start at step 8
M552 S-1 to disable
M552 S0 to make idleFIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3beta2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-03-10 13:41:12 ok m552 WiFi module is connected to access point , IP address 255.255.255.255 ok M552 S-1 WiFi module stopped ok M552 S0 ok WiFi module started M552 WiFi module is idle ok M587 S”BTWholeHome-SCX2” P”kcE4CFYmW7mU” M552 S1 ok WiFi reported error: Unexpected WiFi state ‘idle’ while trying to connect to WiFi module is idle WiFi module is idle WiFi module is connected to access point , IP address 255.255.255.255
What gives???
I've run it a few times in SerialTools connected by USB, how come its not assigning a proper IP? What did I miss guy's? -
Figured it out, I thought my double quotations "" set in keyboard settings were in straight down format but they weren't, didn't even know it was a thing. If it helps anyone else here it is lol.
Connect to the network straight away.
