Ender 5 + Duet wifi starts on wrong side g29
yes with the '!'
O.K , I'm hoping you are doing this which the head in the middle of the bed ?
Try removing the ! and try running the macro again.
it will move now with '!'
but the origin 0,0 back right the webinterface showa me back right 235,235
o.k , will have the switch Normally open or Normally close part working and tested .
( I will assume you are centring the head each time )
NEXT TEST , try the same macro , while it's moving touch the X axis switch first and it should stop and move in the Y direction , touch than Y switch and than should stop and say homed X and Y .
yes everytime in center the bed
Test succesfull x and y are homed
but why on right back ( 0,0 ) is now 235,235 and not 0,0 ?
Left , front is 0, 0 , right / back and fully homed should be 235 , 235 ,
Did my macro go right and back towards the X and Y homing switches ?IMPORTANT have you a Ender 5 ( not pro or plus )
a few change to the homing file , but it is now much easier to set up , now you don't have a bltouch but a switch for z axis .
