Output buffer exhaustion/Error 0x04 after uploading job
I am watching how since 3.2 (maybe even with 3.1.1 but I didn't notice it...) that before uploading a job and immediately after when the job starts I see Buffers were maxed and the error code changes.
Before uploading the job after the machine has been freshly restarted:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later + DueX5 Board ID: 08DGM-917NK-F23T0-6J1F6-3SD6T-1GBWD Used output buffers: 3 of 24 (20 max) === RTOS === Static ram: 23460 Dynamic ram: 72608 of which 24 recycled Never used RAM 15988, free system stack 197 words Tasks: NETWORK(ready,180) SENSORS(blocked,25) HEAT(blocked,309) DUEX(blocked,35) MAIN(running,450) IDLE(ready,19) Owned mutexes: === Platform === Last reset 00:00:20 ago, cause: software Last software reset at 2021-02-02 15:06, reason: User, GCodes spinning, available RAM 15564, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 44.8, current 45.6, max 45.8 Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, standstill, SG min/max not available Driver 8: position 0, standstill, SG min/max not available Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 2021-02-02 15:07:10 Cache data hit count 27570145 Slowest loop: 10.68ms; fastest: 0.22ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.9ms, write time 53.4ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 68.70ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === Filament sensors === Extruder 1: pos 247.50, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === DueX === Read count 1, 2.90 reads/min
To immediately after uploading a job file (10MB in size) and the job is starting, this is still at the warm up phase of the print!
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later + DueX5 Board ID: 08DGM-917NK-F23T0-6J1F6-3SD6T-1GBWD Used output buffers: 10 of 24 (24 max) === RTOS === Static ram: 23460 Dynamic ram: 72608 of which 24 recycled Never used RAM 15988, free system stack 191 words Tasks: NETWORK(ready,180) SENSORS(blocked,25) HEAT(blocked,309) DUEX(blocked,35) MAIN(running,450) IDLE(ready,19) Owned mutexes: === Platform === Last reset 00:01:05 ago, cause: software Last software reset at 2021-02-02 15:06, reason: User, GCodes spinning, available RAM 15564, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU temperature: min 45.1, current 45.4, max 45.8 Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, standstill, SG min/max not available Driver 8: position 0, standstill, SG min/max not available Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 2021-02-02 15:07:55 Cache data hit count 96696755 Slowest loop: 253.77ms; fastest: 0.22ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 8 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.3ms, write time 39.9ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "M190 S70" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 254.18ms; fastest: 0.06ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === Filament sensors === Extruder 1: pos 247.50, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === DueX === Read count 0, 0.00 reads/min
This is with a Duet2 Ethernet with a Duex5. Trying to figure out if there is something going on that I should know about or do something about.
My config is here:
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed May 13 2020 20:53:22 GMT-0600 (Mountain Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Joes BFPv3.2" ; set printer name M929 P"eventlog.txt" S1 ; Set event log M575 P1 S1 B57600 ; Enable Panel Due Port. M555 P2 ; Set firmware compatibility to look like Marlin G21 ; Work in millimetres ; Network M552 S1 ; DHCP ;M552 P192.168.50.45 S1 ; enable network and set IP address ;M553 P255.255.255.0 ; set netmask ;M554 P192.168.50.1 ; set gateway M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S0 ; disable Telnet ;##########Motor/Movement/Build Area############## ; Movement section M569 P0 S0; Drive 0 goes backwards(change to S0 to reverse it) -X M569 P1 S1 ; Drive 1 goes forwards ZL M569 P2 S1 ; Drive 2 goes forwards ZR M569 P3 S0 ; Drive 3 goes backwards E0 M569 P4 S1 ; Drive 4 goes forwards E1 M569 P5 S1 ; Drive 5 goes forwards U M569 P6 S1 ; Drive 6 goes backwards Y M569 P7 S0 ; Drive 7 goes forwards Y ;M569 P8 S1 ; Drive 8 goes forwards ;M569 P9 S1 ; Drive 9 goes forwards ; Motor Assignments M584 X0 Y6:7 Z1:2 U5 E3:4 ; U Axis for second X stepper, dual X and Dual Y and dualZ M350 Z16 I1; M350 X16 Y16 U16 I1; Configure microstepping with interpolation M92 X200.00 U200.00 Y200.00 Z1600 E809.00:825.00 ; set steps per mm ; FEEDRATE CONVERSIONS ; 20mm/s = F1200 ; 70mm/s = F4200 ; 120mm/s = F7200 ;200mm/s = 12000 M201 X1400 Y1200 U1400 Z500 E7000:7000; Accelerations (mm/s^2) M203 X15000 Y15000 U15000 Z1800 E15000:15000 ; Maximum speeds (mm/min) M205 X13 Y13 U13 Z8 E50:50 ; Maximum jerk speeds mm/sec M566 P1 ; Set Jerk Policy to 1 M204 P3000 T4000 ; Set printing and travel accelerations M906 X1100 Y1350 U1100 Z1150 E900 I15; Set motor currents (mA) and motor idle factor in percent M84 S240 ; Set idle timeout ;############Call Pressure Advance / Dynamic Acceleration ######## M98 P"/macros/jobscripts/PressureAdvance.g" ;Printable volume 305x 310y ;M208 X152.5 Y174.5 U203.78 Z300 ; Set axis maxima (adjust to suit your machine) U 203.35 original - Tweaking to 203.78 to test aligment (moving to the left) ;M208 X-198.5 Y-189.5 U-152.5 Z0 S1 ; Set axis minimum (adjust to make X=0 and Y=0 the CENTER of the bed) -3mm between the X and U wit the U being 3mm further back, so add -3 to the Y number ; Home to the Min of X, Max of Y, Max of U set that to get the center zero. Use the non home axis as travel limits. M208 X152.5 Y180.4 U200.28 Z300 ; Set axis maxima (adjust to suit your machine) U changed to 200 (Added.25 to align IDEX printing on U, moved it slightly to the left.) M208 X-200 Y-189.5 U-152.5 Z0 S1 ; Set axis minimum (adjust to make X=0 and Y=0 the CENTER of the bed) X Changed to 200 -3mm between the X and U wit the U being 3mm further back, so add -3 to the Y number ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 U2 S1 P"e0stop" ; configure active-high endstop for High end on U via pin e0Endstop ;M574 Z2 S1 P"zstop" ; configure active-high endstop for low end on Y via pin zstop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ;Motor Stall Detection M915 X Y U F0 R2 S15 M915 Z F0 R2 S30 ;Code to calibrate the lead screws M671 X-265:265 Y0:0 S1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis Max correction of 1 ; #######Z-Probe####### M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H3 F75 T2000 A10 R0.8 S0.004 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X16 Y28 Z1.235 ; Set Z probe trigger value (Higher the number the closer to the nozzle) ( was 1.12, -.17 delta needed after rebuild) M557 X-150:150 Y-150:150 S50 ; define mesh grid M376 H3 ; Taper off compensation over 3mm of height ; ##########Heaters/Sensors################### M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat"T0 Q10 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S135 ; set temperature limit for heater 0 to 135C M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 ;V6 Thermistor Cartridge E0 ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp ;V7 Beta Thermistor E0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 Q100 ; create nozzle heater output on e0heat and map it to sensor 1 ;M143 H1 S285 ; set temperature limit for heater 1 to 285C ; V7 300C Max temp M143 H1 S315 ; set temperature limit for heater 1 to 300C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ;V6 Thermistor Cartridge E1 ;M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp ;V7 Beta Thermistor E1 M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 Q100 ; create nozzle heater output on e1heat and map it to sensor 2 ;M143 H2 S285 ; set temperature limit for heater 2 to 285C ;V7 300C Max temp M143 H2 S315 ; set temperature limit for heater 2 to 300C M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ;PT1000 calibration sensor ;M308 S8 P"duex.e5temp" Y"pt1000" A"Calibration"; sensor 8 (disabled for when not being used) ;Virtual Sensors M308 S3 P"mcu-temp" Y"mcu-temp" A"MCU" ; set virtual heater for MCU M308 S4 P"drivers" Y"drivers" A"Driver" ; set virtual heater for stepper drivers ;DHT Sensor M308 S5 P"duex.cs6" Y"dht22" A"Chamber Temp" M308 S6 P"S5.1" Y"dhthumidity" A"Chamber Humidity" ;############Call Filament Sensor Configurations######## M98 P"/macros/jobscripts/FilamentSensor.g" ; ##########Fans############# M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"E0 Part Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"E1 Part Fan" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off M950 F2 C"fan2" Q1 ; create fan 2 on pin fan2 and set its frequency M106 P2 C"System Board Fans" S0 H3:4 T44:55 L50 X255 ; set fan 2 name and value. Thermostatic control is turned on M950 F3 C"duex.fan3" Q500 ; create fan 3 on pin duex.fan3 and set its frequency M106 P3 C"E0 HE Fan" S1 H1 T80 L0 X255 ; set fan 3 name and value. Thermostatic control is turned on M950 F4 C"duex.fan4" Q500 ; create fan 4 on pin duex.fan4 and set its frequency M106 P4 C"E1 HE Fan" S1 H2 T80 L0 X255 ; set fan 4 name and value. Thermostatic control is turned on M950 F5 C"duex.fan5" Q500 ; create fan 5 on pin duex.fan5 and set its frequency ;#####LEDS########### M106 P5 C"Pause LED" S0 H-1 ; set fan 5 name and value. Thermostatic control is turned off M950 F6 C"duex.fan6" Q500 ; create fan 6 on pin duex.fan6 and set its frequency M106 P6 C"E0 LED" S0 H-1 ; set fan 6 name and value. Thermostatic control is turned off M950 F7 C"duex.fan7" Q500 ; create fan 7 on pin duex.fan7 and set its frequency M106 P7 C"E1 LED" S0 H-1 ; set fan 7 name and value. Thermostatic control is turned off M950 F8 C"duex.fan8" Q500 ; create fan 8 on pin duex.fan8 and set its frequency ;M106 P8 C"Bed LED" S0 H-1 ; ###Commented out, no longer bed fan####set fan 8 name and value. Thermostatic control is turned off (### Going to bereplaced with chamber fan script) ;##### 24v Duex Heaters as Fan outputs ;M950 H3 C"duex.e3heat" Q500 T8 ;M141 H3 P0; Set chamber heater Not needed right now ;M106 P9 C"DummyHeater" S255 H-1 ;M950 F10 C"duex.e4heat" Q500 ;M106 P10 C"HeaterLED2" S255 H-1 ;M950 F11 C"duex.e5heat" Q500 ;M106 P11 C"HeaterLED3" S255 H-1 ;M950 F12 C"duex.e6heat" Q500 ;M106 P12 C"HeaterLED4" S255 H-1 ;############Call Chamber Fans########## ;M98 P"/macros/jobscripts/ChamberFan.g" ;########Cold Extrusion Limit########## M302 S185 R185 ;Filament settings M404 N1.75 D0.4 ;############Extend TEMPERATURE FAULT WARNINGS - ONLY FOR Nozzle/Tool changes ;M570 H1 P90 T80 ;Heater 1 (E0) Extended Fault Warnings ;M570 H2 P90 T80 ;Heater 2 (E1) extended fault warnings ;Disable heater warnings for ;###TOOL DEFINITIONS#### ; Tool 0 X - Left hand Extruder M563 P0 D0 H1 F0 X0 S"Left Titan Aero" ; tool 0 uses extruder 0 and heater 1 and maps X to X, use fan 2 as the print cooling fan G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets ;G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ;Tool 1 U - Right hand Extruder M563 P1 D1 H2 X3 F1 S"Right Titan Aero" ; tool 1 uses extruder 1 and heater 2 and maps X to U, use fan 1 as the print cooling fan G10 P1 X0 Y-6.65 Z0 ; Set initial tool 1 active and standby temperatures to 0C (Higher the negative number the futher back the U axis alings) ;G10 P1 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Duplication Tool 2 M563 P2 D0:1 H1:2 X0:3 F0:1 S"Dual Duplication Print" ; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans G10 P2 X76 Y0 U-76 Z0 ; set tool offsets and temperatures for tool 2 ;G10 P2 R0 S0 M567 P2 E1:1 ; set mix ratio 100% on both extruders ; Mirror Tool 3 M563 P3 D0:1 H1:2 X0:3 F0:1 S"Dual Mirror Print" ; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans G10 P3 X85 Y0 U-85 Z0 ; set tool offsets and temperatures for tool 2 (+10mm offset for clearance due to the mirroring movements) ;G10 P3 R0 S0 M567 P3 E1:1 ; set mix ratio 100% on both extruders ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory
