Duet 2 Wifi with generic Max31865
Hi All,
I just want to confirm what I am doing is ok and correct and to get some help with some configuration.
I have upgraded my Duet 0.8.5 with a Duet 2 Wifi running Firmware 3.11. I already had a generic Max31865 for my PT100 sensor and want to continue using this with the Duet 2 as it works OK.
Previously I have it connected to the 50 pin connector as shown here. Now on the Duet 2 WiFi I have it connected as follows.
Is this correct and how do I go about telling the Duet which channel to use? Would is be as simple as adding this
M308 S1 P"spi.cs0" Y"rtd-max31865"
to the config.g and what M950 command would assign it to the hot end?
Thanks
M308 S1 P"spi.cs0" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M143 H1 S280 ; set temperature limit for heater 1 to 280CM563 P0 D0 H1 F0 ; define tool 0
the https://configtool.reprapfirmware.org/ will help you with this
Thanks
