DWC Z - Axis Movement off by Factor 10
@BoA said in DWC Z - Axis Movement off by Factor 10:
M591 D0
Response: Extruder 0 has no Filament Sensor
@Frederik BMG with 0.9 stepper + 16 microsteps should have 830steps/mm
i will try it. on moment
@Frederik Paste Your config.g only and result of
M98 P"config.g"
; generated by RepRapFirmware Configuration Tool v3.1.7 on Wed Nov 18 2020 18:04:17 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M550 P"Duet 3" ; set printer name
M669 K1 ; switch to CoreXZ mode and multiply motor movements by 3 for the Z axis; Drives
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M569 P0.3 S0
M569 P0.4 S0
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M584 X0.1 Y0.0 Z0.2:0.3:0.4 E0.5 ; set drive mapping
M671 X425:200:-25 Y240:-25:240 S1 P1.25 ; leadscrews at front left, rear middle and front right with 1mm per screw compensation; Movement Parameters
M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
M92 X160.00 Y160.00 Z400.00 E830.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
M906 X1800 Y1800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X400 Y400 Z385 S0 ; set axis maxima; Endstops
M574 X2 S1 P"!io1.in" ; configure active-high endstop for high end on X via pin !io1.in
M574 Y1 S1 P"!io0.in" ; configure active-high endstop for low end on Y via pin !io0.in
M574 Z2 S2 ; configure Z-probe endstop for low end on Z; Duet Laser Filament Sensor
M591 D0 P5 P"io3.in" R40:120 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to IO 3,
tolerance 40 to 120%, 3mm comparison length, enabledM350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
M92 X160.00 Y160.00 Z400.00 E837.02 ; set steps per mm
M906 X1800 Y1800 Z1000 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X400 Y400 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-26 Y2 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X0:400 Y0:400 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M143 H0 S200 ; set temperature limit for heater 0 to 200C
M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
M106 P0 C"Hotend" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
M950 F1 C"!out4" Q500 ; create fan 1 on pin !out4 and set its frequency
M106 P1 C"Bauteildüse" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off; Tools
M563 P0 S"E3D V6 0.4 Steel" D0 H1 F0:1 ; define tool 0
T0 ; select first tool -
@Frederik said in DWC Z - Axis Movement off by Factor 10:
M84 S30 ; Set idle timeout
M574 Z1 S2 ; configure Z-probe endstop for low end on Zthis section is still in your config twice
wow, i dont know why its doubling these lines ?!?
in my normal config. in DWC there is this section only once
@Frederik drag and drop file instead of copy paste content
ok.
i restartet my DWC and now it looks good i think -
M591
i get always the error M591 no pin name given.
do i have to use the m950 command befor to create a pin ?
WOW, Thank You soooo much.
Now my Z Axis working almost spot on...only minor adjustments needed.
Your Tip with the Extruder E steps was perfekt.
now there is only the error message from the filament Sensor ,
and i have to try if the auto bed leveling with the 3 independet z motors will work as expected with my BLTouch.
What Slicer do you use or recommend ?
I tried
Cura 4.8.0 and Prusaslicer .Simplyfy 3d looks also realy nice, but i cant find a demmo version or similar. Its a hefty Price Tag for a Slicer and when i am reading the reviews on the internet ,i dont know if it is good at the moment with 4.1 or should i wait till the new update is released ?
