Timelapses, are they possible?
@the_dragonlord said in Timelapses, are they possible?:
@resam said in Timelapses, are they possible?:
Whats your current
ExecStart
line? I think you might have messed around with it a bit too muchuh surely, how can I see the ExecStart?
Thanks for everything....it didn't create the video at all
I've pushed another update - turns out I had the ffmpeg option disabled instead of enabled.
With the latest update you need to pass in this extra command line argument:
--run-ffmpeg
--run-ffmpeg
execellent!! Have yoy solved the auto start issue too?
--run-ffmpeg
IT WWWWWWOOOOORRRRKKKKKKSSSSSSSSSSSSSSSS!!!!!!! Great jon my friend, great job!!! Thanks a lot for everything!!!
ok, it works with the example print but not with mine....I've inserted the GCODE in the layer change but it doesn't take the pictures...tha GCODE works because when the layer changes I see the nozzle stopping for a while....I'm using Ideamaker as slicer....any idea?
EDIT:
It started to wokr after about 6-7 layers....they are not so small layers, it take about 30-40 secs each to complete
