Would be nice to set FAN target speed by RPM instead of PWM
@BoA
i think the hardware overview makes it pretty clearhttps://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview
6 PWM controllable fan channels. 3 of these support 4 wire fans including tacho reading. These can be run from either the input voltage, from 12V, or from external power for added flexibility. Also one always-on fan connector supplied with VIN voltage.
@Veti Ok. I will give it a try soon
@BoA said in Would be nice to set FAN target speed by RPM instead of PWM:
My concern was voltage on tacho pin and pwm pin.
they're generally active low to avoid voltage issues
