To rigidify or not to rigidify? - vibration issues
@Nxt-1 said in To rigidify or not to rigidify? - vibration issues:
@H2B
I wonder how applicable that technique is to the size of machine I have.@mrehorstdmd said in To rigidify or not to rigidify? - vibration issues:
How about a couple strap clamps?
I tried with the only strap clamp I could find and did not really notice a significant difference sadly, worth the try though.
I suspect that right now, adding more rigidity is not going to do anything. In fact its probably just going to add things that can resonate.
@theruttmeister
I got myself four bag of ready to concrete mix and will play with it, hopefully in the coming days. Most likely I will go with the M5 bolt+t-slot nut approach as drilling holes trough the extrusions is just asking for troubles with all the interrupted cuts, at least with the tool I have at my disposal. I'll report my findings once I have something to report.That seems the most sensible path. You can use the same 3D printed mold technique you used for the base, and mold the through holes for bolts right into the concrete. Don't forget a draft angle!
3 molds cut
2 molds assembled
1 mold filledIf the other sides of the concrete slab look anywhere near as nice as the top surface, I'll be real happy. Oh, and I added blue pigment to the mix
I plan to mix and pour the other two slabs as the extra pigment I ordered arrives. I also got myself a box of M8x80 bolts and matching t-slot nuts for attaching the slabs to the towers.
@Nxt-1 I would install cement anchors as long as the cement is wet.
If you make new ones, I would suggest reinforcement steel inside and preproduced holes (filled with eg polystyrol), so you don't need to bore holes when the concrete is dry, with the risk of cracks. For a nice side, using molds from concrete formwork panel (screen printed plate, german Betonschalungsplatte) give a smooth surface.
@JoergS5 Anchors would do me any good and there would be no way to screw a bolt into them once the slabs sit against the towers. As others suggested, I did think about printing some pieces to serve as bolt holes spacers (all the way through) but in the end I decided that I will drill the holes with a rotary hammer drill. If it gives me to much of a pain in the [redacted] I can still go that route for the two remaining slabs.
@Nxt-1 I added some information to my post as suggestions. I wish you success, mixing blue color into it is a very good idea, this looks really great!
I too would prefab the holes to reduce risk of cracking when drilling; fingers crossed!
@JoergS5 I think all of you suggestions are good points, heck they might even be smarter to do. The reason I did not go for the betonplex wood (as it is called in Dutch) is simple, I had a large plate of this wood at hand and didn't feel like buying a fresh sheet of the smooth wood just for this
@bearer @JoergS5 I have drill a few holes in concrete the last months, more than I'd like tbh, but never had cracking issues. Maybe I am naive but unless this slab is just to thin to resists cracking, I don't feel worried. * knocks on wood *
@Nxt-1 To have a lot of experience increases the chances very much
@Nxt-1 the only issue with that is the screws will still transmit vibration. True vibration mounts are isolated between the screws too. I had them on my CoreXY and it was much quieter than with out. The only issue I had was how they attached with some really long spacers and only two spots added some elasticity in the lotion that I disliked more than the noise.
@baird1fa You are 100% correct. I have already placed an order for proper nema 23 dampers, but they will take a while to arrive.
@baird1fa Thinking about this for a while longer, I expect the proper dampers to help but not really solve the issue. I believe a lot of the vibrations will still get coupled to the frame via the axle/bearings/belt combo. And I don't think there really is any way around that, except maybe making the whole motor mount of out tpu
For a Delta it is not necessary to over regidify the frame. The mass of the print head in comparison to the printer is very low. There are no heavy axis which have be pushed. Print artifacts on Deltas seem generally more linked to exruder issues. Your built btw looks already relatively steady. All the work to make the printer more stable will very probably change nothing.
@dgrat said in To rigidify or not to rigidify? - vibration issues:
While you might be right that extra rigidity will not help. At the same time we are not trying to make the frame more rigid with the concrete slabs. Just trying to increase the mass, which should reduce vibrations, or lower the resonant frequency of the frame to be precise.
@Nxt-1 you would be surprised how much the proper mounts help. Belts donโt really transmit vibration as they are already vibration dampers. If you donโt have good linear bearings then that will cause vibrations but i suspect you do have good linear motion components.
If you are using aluminum extrusion filling it with something viscous (hydraulic oil or honey) would help in 2 ways. One it would dampen vibrations and it would also fill the resonance chamber with a fluid that would change the speed of the sound waves.
@baird1fa said in To rigidify or not to rigidify? - vibration issues:
I don't disagree that proper stepper damper can do wonders, I have actually used them with success in the first iteration of my printer (nema 17 that time). The issue here is that the motor rigidly connects to a 2nd shaft which holds the pulley. That shaft is supported by two bearings, which sit inside the whole bracket. So there is a rigid connection from the stepper to the axle through the bearings into the frame. What I said is that a damper will not solve that part of the problem.
I indeed use high quality THK SRS_WM rails, they will not be a source of significant vibrations.
If I had not previously filled the towers with just pain sand, this would be a way easier solution. Right now, I don't have means of getting the sand out of the 1,5m long extrusions without turning the printer upside down, which I am definitely not doing unless it is my last resort.
I think what you do is nice, but I honestly don't think it will be worth the investment. Nevertheless, do you have some close up pictures of prints? Please show, what is pushing you forward. I wonder, whether it wouldn't it be smarter to reconsider the effector. Your effector looks rather heavy because of the watercooling. It might be wiser to enhance the rod mechanics and widen the arm distance.
Why do you think adding concrete to increase mass, in effort to reduce vibrations will not be worth the investment? (I am not sure either until I try it, just curious)
I do not have pictures of recent prints, heck this version of the printer, with the new rails, steppers etc just printed 1 little cube to confirm all was working. Unless I am missing something, I do not really see why a print closeup is relevant here? I am not trying to improve print quality, only battling audible vibrations.
The pictures/video of the effector in it current state are kind of misleading. Normally, all the water cooling stuff, as well as the extruder is fully supported by the 4th axis. Currently it is not as since the upgrade, there were some unanticipated changes how the 4th axis fits in, and well, it doesn't fit at its designed location. Rest assured once I redesign the 4th axis to fit like it once did, the weight on the effector is about identical to a regular bowden fed smart effector.
Well, the effector of my Deltas is ~0.13kg. With 200m/s travels and accel values of ~3000-5000 mm/sยฒ i get usually 0.2g of vibrations. This is nothing in comparion to my Ender-5. Movable x-axis probably 2 kg. Additionally, the case of the ender is already way less than the weight of my Deltas. I don't underestimate if I say, that the whole Ender is shaking if I set acceleration to 3000 mm/sยฒ. Haven't taken a measurement, but but acceleration is probably in the order of 1-2 g, maybe more. Print quality on both machines is decent, beside stringing issues (Deltas with 200 mm/s travel and 60 mm/s print mainly because the BMGs become less reliable to deliver filament at 0.25 mm layer heights). Also I think it is just more economical to reduce weight of the effector than increasing weight of the frame.
please post some print pics
@dgrat I am sorry that I am going to be blunt, but I really think you don't get what the issue is I am trying to solve. I am not looking to improve print quality, there is no issue there. Even if I remove the effector, the arms and all else you desire except for the motors and belts the frame still resonates at about 800Hz. Once again the effector and its mass, large or not, is not relevant in this case.
Again, I have no prints done with this machine yet, so stop asking for print pics. If I was trying to solve wavy prints or stuff like that, sure. But not in this case.
