TEVO Little Monster Duet Ethernet Conversion
I figured half the problem with the bltouch.
My wiring was incorrect. I was using the all 4 z probe pins (connector next to paneldue) + 1 e0 stop pin. Instead, i am now using 2 z probe pins (z probe in and ground) + 3 expansion pins (1, 2, & 8).With that wiring, the bltouch pin drops and retracts at startup and during calibration of the first point but does not move to the second point. This could be a matter of playing with config.g.
No logging is displayed during calibration.
Really tempted for the Mini IR scanner as a replacement as im not fond of bltouch anyways.Also, i have tried some simple commands through the paneldue. Pressing the return just clears the line. I cant tell if the duet registers anything. Also, i only have 4 wires connecting my duet (in connector next to z probe on the duet) and paneldue.
I figured out the calibration problem. The other half was tweaking stuff in config.g. looking good so far! Thx!
Great post I am getting ready to do the same thing to my tevo monster I was hoping to get a copy of your configuration files to give me a good starting place
